What cams should I go for?
Old May 19, 2009 | 01:01 PM
sirt_eg's Avatar
Default What cams should I go for?
Got a ls/vtec high compression with maybe 11.2 or 11.6, not to sure which one but its p73 piston. b18a1 block/b16a2 head. The head is build, with high compression supertec valves and dual valvespring, with brian crower retainers. All new seals, and a valve job done. I was suggesting the pro 2 but I dont know if its too agressive for my setup. Thumbs up or Thumbs down? maybe the tuner 2 instead?
Thought about getting the itr for some small hp gain but the cost is already as much as the s1s1 and half the price of a s2s2. hmmm any suggestion?
Old May 19, 2009 | 01:11 PM
Ruben19's Avatar
Default Re: What cams should I go for?
skunk2 stage 2 is fine.
dont get pro 2
Old May 19, 2009 | 01:50 PM
sirt_eg's Avatar
Sounds good enough. I'm guessing you mean the skunk2 stage 2 tuner.
i need help!
Jan 24, 2009 08:47 AM
insidiouseg-6
15
Apr 22, 2008 08:29 PM
buffgsr
Dec 16, 2006 01:06 PM
The G2 Racer
17
Mar 29, 2005 08:10 PM
