parking brake coming on....????
So when driving if I quickly accelerate the parking brake light comes on.
And when I hit the brakes it comes off. I checked the parking brake
switch (even disconnected it) but that isn't it.
I'm thinking it may be the TCM or the PCM (I'm a beginner at this stuff)
I pulled the power backup fuse for 10 sec (to reset the PCM) but it didn't solve the problem.
Any suggestions?
Any suggestions?
There is a float in the brake fluid reservoir, if the fluid is low it will trigger the brake light.
The fluid is probably sloshing around when you accelerate/brake causing the light to go on and off.
Correct! So make sure you don't top off the fluid if your brake pad levels are low. Because if you fill the reservoir with fluid, when it comes time to replace the pads and you begin to push the brake piston back in, the fluid will start to gush out the top of the reservoir.
Manmeetsingh
May 20, 2014 08:06 PM
adamcm16
Apr 10, 2014 05:07 PM
Tench
May 11, 2004 10:23 AM
