B16 worked head, BNIB Skunk2 Cams, other parts
Old May 19, 2009 | 12:27 PM
1993dagsr's Avatar
Default B16 worked head, BNIB Skunk2 Cams, other parts
For pics visit - http://photobucket.com/partshonda
B16 BUILT HEAD - 700$
brand new Skunk2 Valve springs and retainers, NEW OEM Valve Seals, 3 angle valve job, light port job, cleaned and looking NEW, b16 cams, BNIB OEM cam cap bolts(50 bucks in bolts), b16 intake mani, vtec solenoid, type R fuel Rail
Other PARTS-
Skunk2 STAGE 2 CAMS - 1 set NEW in BOX - 300$, 1 set used - 250$
RC 440 Injectors used OB1 clips - 125$
CM stage 2 clutch used 1000 miles - 75$
Golden Eagle 84 mm head gasket BNIB - 70$
TODA lightened flywheel 9.5 lb - 125$
b16 intake manifold - MAKE OFFER
BNIB type r/gsr TIMING BELT from HONDA - 50$
TYPE R FUEL RAIL - Make Offer
NEW HASTINGS 81.5 mm PISTON RINGS - Make Offer
Text or call 786-419-9238
Old May 19, 2009 | 05:01 PM
chadzvtec's Avatar
Default Re: B16 worked head, BNIB Skunk2 Cams, other parts
how much for the head and are the s2 cams turbo or na. bump for great prices on the cams
Old May 19, 2009 | 08:48 PM
1993dagsr's Avatar
the head is 700$...cams are TUNER SERIES stage 2s
Old May 19, 2009 | 09:09 PM
magcrf's Avatar
replied
Old May 19, 2009 | 10:38 PM
91crxlsvtec's Avatar
where are you located at, interested in new sk2 st2 set
Old May 20, 2009 | 06:03 PM
cnydc2's Avatar
Willing to ship injectors, and would timing belt work on w gsr block and b16 head?
619craig
Apr 19, 2013 04:17 AM
Nickb257
Northeast (Sales)
Jun 25, 2009 02:26 PM
1993dagsr
May 19, 2009 08:42 PM
turbo*s2k
Sep 25, 2003 01:27 PM
