Help installing JDM crx rear seat
Old May 19, 2009 | 12:27 PM
clovis88crx's Avatar
Default Help installing JDM crx rear seat
anyone installed one in a 1988 crx si? the write-up i found says to bolt the seatbelt to where the 88 crx pillar mounted belts are.
if you have installed one, where did you bolt them down at? pics would be nice
also can everyone give input on what is better: bolting down the brackets, riveting the brackets in, or welding them in.
thanks for help everyone
Old May 19, 2009 | 12:38 PM
Canadian_EF's Avatar
Default Re: Help installing JDM crx rear seat
link to write up for a different interpretation?
Old May 19, 2009 | 01:57 PM
heres the only link i can find. thanks for any help.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-jdm-edm-backseat-installation-1719845/
under step 4: seatbelts
second pic has a red box around where my stock pillar mount seatbelts are. so not sure where to mount the jdm/edm seatbelts
Old May 19, 2009 | 04:13 PM
i would think to just bolt both belts into that spot?
Old May 19, 2009 | 05:00 PM
DoubleEx's Avatar
ok on mine i bolted the belts to the pillar bolt at the bottom. On the 2 bolts that go under the seat i slid the seat in with belts and marked the best location. get bolts with washers and nuts, drop gas tank down, drill holes and install. I used 4 rivets on each of the seat tilt bracket.
Old May 19, 2009 | 08:17 PM
thanks for the info
skipbudlong
Jan 23, 2012 10:40 AM
bobalee
Feb 2, 2007 09:10 AM
EF8 JUNKIE9
Jun 14, 2005 01:52 PM
JimmyHafada
Mar 5, 2003 12:42 PM
DIY_Racing
Sep 19, 2002 08:59 AM
