How to remove Evap Nipple from Throttle Body?
Old May 18, 2009 | 09:02 PM
Colin's Avatar
Default How to remove Evap Nipple from Throttle Body?
I have a little project I'm trying to figure out and it involves installing an EVAP nipple on a TB which does not already have one. I have a donor TB but was wondering the best method by which to remove the EVAP nipple from it so that I can install it on the other TB. I'm guessing it's just pressed in place. I tried using pliers but it wouldn't budge. I figure I'll try heating it next to see if I can get it to break loose, but wanted to get some input just in case there's something critical I'm missing.
For those that are wondering, the EVAP nipple I'm talking about is the one that the braided red hose connects to on the top of the TB on many older b series engines. I can provide a pic if needed.
Any advice or input is appreciated. Thanks!
Old May 18, 2009 | 10:37 PM
redboost10's Avatar
Default Re: How to remove Evap Nipple from Throttle Body?
heat it up with a torch and it will come right out, same with the one on the valve cover
Old May 19, 2009 | 05:00 AM
Colin's Avatar
Cool, I was pretty sure that was the case but never hurts to double check. Thanks!
piggydog
Aug 8, 2010 02:57 PM
sageuvagony
Aug 12, 2008 09:09 AM
civic_driver
97
Jul 27, 2007 06:28 PM
stackz
Oct 4, 2006 07:06 AM
Civic Hybrid
Jun 13, 2006 10:54 PM
