stock LS turbo went to the track(now upset)
Old May 18, 2009 | 07:49 PM
goldhatch94's Avatar
Default stock LS turbo went to the track(now upset)
well befor lookin in here i was happy with my times for my set up till i came on here and see some one went 11's on a stock Ls now i am going to go beat it up more
well i went to the track 1990 SI crx.
bone stock b18a CoreyR mini ram ebay 57trim on 13 psi my best pass was 13.1 at 108 shitty 60 foots.
i was pushing it for a 12.9 but ran otu of time.
http://www.youtube.com/watch?v=E0OeT_Q-bs0
http://www.youtube.com/watch?v=YovPW...eature=related
Old May 18, 2009 | 07:51 PM
Default Re: stock LS turbo went to the track(now upset)
http://www.youtube.com/watch?v=dtoz2cTMCq0
Old May 18, 2009 | 07:55 PM
cfwthb_94's Avatar
hey you gotta start somewhere. Keep it up though and you'll get there. I waiting a long time before I was able to get to where I am. And I'm not even that fast compared to others
Old May 18, 2009 | 07:58 PM
i am not lookin to be that fast i am just playing around with this motor i have a piston and rod motor with a built head sittin on the stand i just can take a good running motor out yet lol
Old May 18, 2009 | 08:02 PM
Kelvin Racing's Avatar
Tell more about your setup like dyno #'s, what tires were you on along with 60ft times.
Trapping 108 I really think it's just lack of power.
With my 2000 Integra GS. Full leather interior AC/PS. Ebay turbo kit OBD2B(untuned) 91/93octane(Around here some pumps are different), 9lbs of boost Fmu, walbro 255 AND Stock Injectors, with Falken Azenis I went 13.3 @107 2.0X 60'.
If anyone knows about how much power they think I was making let me know.
Old May 18, 2009 | 09:28 PM
FRANKBUILT's Avatar
I would say you were making 230 240,
Old May 19, 2009 | 04:18 AM
i was on low pro all motor slick it was all i could get at the time
Old May 19, 2009 | 04:30 AM
BoostR41's Avatar
in a light crx I would say you are under 200whp. get it tuned
Old May 19, 2009 | 02:14 PM
it is tuned.
Old May 19, 2009 | 05:31 PM
cfwthb_94's Avatar
Hell if you have another motor sitting around just turn the boost up. lol You're in the same setup I just got out of. I blew the ringlands on a couple of pistons (27psi). The motor was loving 20lbs of boost. And now I have a new motor in now and still having fun.
Old May 19, 2009 | 05:59 PM
i know i am just being lazy lol
Old May 19, 2009 | 06:10 PM
sanman000719's Avatar
well I ran 12.076@122.14 mph with a .652r/t and 1.901 60 foot 1/8 was 7.92@94.04 mph man this was on a stock gsr block, and a t3/.66 trim e85 tuned at 414 whp. so your time isnt all that bad as you see, but seat time means everything because you can only get better homie.
Old May 19, 2009 | 06:12 PM
try to ht the track as much as possible and get them skills built up, and times will fall
Old May 19, 2009 | 06:15 PM
Silva Bullit DC4's Avatar
Amen. Get to know your car, and it will reward you. ;-)
Old May 19, 2009 | 06:20 PM
yeah my car went 11.42 without me the best i could do was the 12.076 i need to learn to build boost before launching lol key thing to learn
Old May 20, 2009 | 11:56 AM
cfwthb_94's Avatar
Use the 2 step and sit there for a while till you start seeing boost build on the guage. It took me a while to get the hang of it. Now I just have to learn to do it while cutting a good light instead of sitting on the line for 6 seconds. I'll have to learn to use the two step to pull me threw the 2nd beam.
Old May 20, 2009 | 11:59 AM
cloviskilla's Avatar
do be disapointed. good job. get a 60 trim garrett
Old May 20, 2009 | 01:40 PM
I hover around 4500 to 5000 rpm after I prestage. I hold that for a while (maybe wait for the other person to stage) while Im preloading to light the staged bulb. By that time, the manifold is super hot, so by the time I get on the two-step (set at 6k, redline-7k), all the fuel that the antilag has dumped thru the combustion chamber and in to my hot manifold INSTANTLY combusts and spools the turbo because of the extra added heat. I learned that by watching the Pro RWD guys. And with a non-pro tree, I got plenty of time to sit there and spool before the third amber turns on. ;-)
When I used to NOT do that, and try to IDLE while prestaging and staging, I would build boost really late once I get on the limiter.
Old May 20, 2009 | 05:20 PM
that was the one this i did not have i needed a 2 set but my tuner was in his car that day and did not have to much time to set one up. i will have it fornext time migth take it back to the track next weekend and try some more
Old May 21, 2009 | 06:48 AM
fastcody1's Avatar
Turn up the boost and get her tuned
Good job
Old May 21, 2009 | 06:54 AM
If what you're saying is that your car is tuned, then maybe you should go somewhere else. There is ALOT more power to be found out of your car for sure.
Old May 21, 2009 | 06:58 AM
JJsMotorsports's Avatar
Icon7 Re: stock LS turbo went to the track(now upset)
I basically started with same set up, But I went to T1 for a tune, I was really bad off the luanch and building boost is good for getting that good 60' like 1.59-1.65 thats on the road to a great et. You need Seat Time with your car. Seat time will help lower your ets. Stay with it!
Old May 22, 2009 | 09:08 AM
DaOnE51T's Avatar
not a bad start.... Time for some slicks, a high boost race gas tune, and more seat time.
Old May 23, 2009 | 07:48 PM
newtype_33's Avatar
u need to get a good set of slicks.
badass3dr
Mar 9, 2013 06:33 AM
fastcody1
May 20, 2009 03:59 PM
dragsol
Sep 10, 2008 09:19 AM
CivicB18C1
Apr 10, 2007 05:54 AM
LS_REX
Nov 16, 2004 01:30 PM
