Need Help on Heads.
I have a 94 4 door with a 1.5 in it,i have found another 1.5 that i think has a good head but it came out of a 95 civic HB, so it is the lower horsepower motor,I was wanting to make sure the head would fit and also it wouldnt drop my horsepower. Also I was wondering if i ported and polished the head ,put a bigger cam and valves in it how much power gain would i make?
I have the basic bolt on's,cat back,intake,header,
soon to have a programmable ECU.
Yea they are the same size,but there is three different types,a 70 horsepower,and somthing like a 80 horsepower and then the one i have is a 100 horse.the one i found is the 70 horse motor,sorry for the confusion.
Well if you were not gay you would probaly find someone to do that,but i am really needing info on this issue.I dont want to put alot of money into a head and it will make my care slower
Depends on how much you're willing to spend. A nice alternative would be to buy a D16 swap from the guys going hybrid. I seen a complete D16 swap with like 40k miles for as low as $350. I'm pretty sure you'll get a little more torque and more choices for upgrades..... dat's my $.02
Yea i know that would be the easy way out to get more power,but i wouldnt mind seeing peoples faces when i open up my hood and they see the singal over head,but thanks for the advice.
BE careful, the cx hatch came with an eight valve 70 hp motor, this will not work on your motor if it came with the 16 valve 1.5l. If the valve cover says "16 valve, you shouldn't have a problem. Why not a d16z6 head? Mini-me=good
Were could i find one of those heads?i was thinking about that at first but then i found out that one of my friends blew his 1.5 and that it still has a good head on it,and the best part is that i am getting it for free.that is why i am going threw this much trouble.
