part out rt4wd wagovan
in so cal. trans is perfect. transfer case has a chipped tooth on the pinion gear-it works but clicks on deceleration. drive shaft with viscous coupling, rear trailing arms, rear diff. now is the time to make your eg,dc or ef all wheel drive... only the drive train is for sale..... but i will sale the realtime 4wd steering wheel if u just have to have it.lol
i went on the fed ex ground website to figure the shipping. it is hard to understand there billing. but the trans ways about 65 pounds. they may charge u for the area it covers. call them and they can give you an accurate estimate to your location. let them know the pick up will be at my shop in delmar.i used to ship parts through DHL but i dont know if they are avaiable to do this shipping any more.i have ratings with paypal and ebay if you look under teamols you will see i even shipeed a mustang complete swap for 800$ shipping cost. i need at least 375 for the trans. it is perfect. it was removed by project import in Anahiem amd sent to Anahiemgear wher it checked out perfect. that when i took off the transfer case and found the chipped tooth.
How hard is the install? Is this all that I will need to do it?If not what else will I need? Will the trans fit a b series engine? I'm interested, just not rich.
575$ tell me which shipping service you want to use and i will put it on a pallet(s) and bring it to them.or they can pick it up at the shop in DelMar cali 92130. shipping large items can be costly you will be paying shipping cost over 575. maybe another 200$. i will work with you a litlle on the shippong cost. treat me fair. these drivel-
ines are not avaible any where.especially a perfect awd tranny.....
