d series turbo build.
Old May 18, 2009 | 01:28 PM
dannyb2134's Avatar
Default d series turbo build.
im running bigger injectors. and i was wondering if i needed to wire a restrictor box to the injector harness, and if so were do i get a diagram. ive googled it and had no luck so dont post use google.
Old May 18, 2009 | 01:55 PM
cbustuner's Avatar
Default Re: d series turbo build.
It doesn't matter if the injectors are bigger, that's not what determines if you use a resistor box or not.What determines that are the injectors resistance.
So my questions for you are what resistance injectors are you running high or low? Also what year car is this build for?
majerst
May 13, 2007 05:29 PM
LU
Apr 16, 2007 04:38 PM
dkk119
Mar 18, 2006 11:36 AM
iBrandon
Jan 29, 2006 02:12 AM
