Need help my civic turbo injector 4 aint working
Old May 18, 2009 | 11:58 AM
mickey b16's Avatar
Default Need help my civic turbo injector 4 aint working
IM STOMPED CANT FIGURE OUT WHY IT NOT WORKNG
ECU IS FINE WIRING IS FINE RESISTOR BOX CHANGED AD MAIN RELAY IS FINE HEEEEEEEELLLLLLLPPPPPPPP:cry:
Old May 18, 2009 | 01:14 PM
Former User's Avatar
Default Re: Need help my civic turbo injector 4 aint working
If you swap injector 4 with another injector, does the problem follow injector 4?
Old May 18, 2009 | 03:52 PM
mickey b16's Avatar
YES THE PROBLEM IS THE SAME, CANT FIGURE IT OUT
Old May 18, 2009 | 04:54 PM
Check whether the wire running between the injector and ECU lacks continuity or has a short. Check whether the other wire at the injector has battery voltage when the key is turned to ON(II). If the wires are fine, then you may have a bad ECU.
Old May 18, 2009 | 05:31 PM
R.Storvick's Avatar
possible the wires to the injector are backwards? other than that, RonJ pretty much covered all i could think of
Old May 18, 2009 | 07:33 PM
mickey b16's Avatar
all wires were chased back to ecu and were fine and everything is getting power i put my stock ecu on for a sec and the problem is the same, im not sure about the injector getting power while only ignition on
salemned
Sep 7, 2017 12:13 PM
turboek03
May 15, 2011 07:32 PM
HondacivDX
Sep 10, 2010 04:12 PM
codyw
Apr 29, 2010 02:23 PM
mickey b16
May 26, 2009 04:02 PM
