keep breaking oil pump
need help with oil pump upgrade. i have broke 2 pumps now on dyno if i boost over 30psi. i have a gsr with b16 crank, turning 9500, any advice would be great!
erl said they did. so i hope so. its been in car for 2 months, it made 702 whp took it to track 3 times, i wanted to see what engine would do so we tuned it more and we made 1 pass at 813 then it broke on next pass. put in new pump made 843 3 times then broke again?
i heard of alot of people having prods with fluid dampr, i've built alot of honda motors but this is my first b18 long rod set up. so i didnt no if that was the prob.
Making that much power, if your reffering that your type r pulley is the wondefull oil pump breaking Ctr pulley. Listen to Jake and James. Get the race version not the street one. And every 2 yrs, send it in to get new balance rings. Just got my new rings back, 1 1/2 week turnaround. ATI
I had the same problem and then installed a fluidmpr and broke another one, finally I assumed it was because I was running a cheap clutch. Changed it and never broke one again even running a stock b18b pulley.
Hmm. I have been running one for a couple years with no issues as many others have. Either way, I would get one for sure and also re-evaluate what clutch you are using.
