Code 43 fuel supply system
Old May 18, 2009 | 09:40 AM
95civic16's Avatar
Default Code 43 fuel supply system
My 95 civic dx coupe with a b18b is throwing code 43. I replaced the injectors and the fuel filter and it still throws the code. It also has a horrible misfire around 2000 rpms when only giving it 1\4 throttle but if i give it more gas when it misses it will pick back up again. idk what it could be. Fuel pump maybe? what do you guys think?
Old May 18, 2009 | 10:30 AM
Utzz's Avatar
Default Re: Code 43 fuel supply system
After you replaced those items, you reset the ECU, correct? Usually this code has to do with an O2 sensor that's about to die. They only last 75k-100k miles and loose service life if they're subjected to rich mixtures, burning oil or coolant.
Old May 18, 2009 | 07:34 PM
95civic16's Avatar
Yes after I replaced both parts i reset the ecu. wouldnt it throw a code for the oxygen sensor if it was that?
Old May 18, 2009 | 07:49 PM
iwanttokillgod's Avatar
i had code 43 and i tried everything even replaced the fuel pump ended up being the fuel return line by the fuel tank had a small hole changed the hose code is gone
Old May 18, 2009 | 08:01 PM
Former User's Avatar
Use an engine stethoscope to determine whether all fuel injectors are clicking when the engine is idling. If the injectors are fine, then test the fuel pressure regulator.
Rhythmsnewsn
Sep 4, 2006 03:30 PM
PhilStubbs
Jan 22, 2005 11:20 AM
im a monster hehe
Feb 20, 2004 09:45 PM
oO
Apr 10, 2003 07:03 AM
VTECVillain
Jun 30, 2002 01:34 PM
