Suggestions For Build N Boosting H22s?
Old May 18, 2009 | 05:36 AM
PreludeTech33's Avatar
Default Suggestions For Build N Boosting H22s?
Well let me start by saying that I have a 95 CD3 Accord Ex with an H22a.
- Im going to build my engine, so I don't know what is a proven set-up.
-I would like to know what brands for the: crank, mains, rod caps, connecting rods, wrist pins, pistons, etc. And what about everything on the top end (should I go titanium), etc.
- Is it a wise choice to sleeve the block? Im going to keep it 2.2 w/o a stroker kit.
What about Wiseco pistons, because I know we used them in the past on motorcycles, and they held up well.
*After its built, can I get a good street/strip turbo set-up for around $1500. I checked out the Greddy bolt-on kits, but there wasn't one up on the site for the H22?
- In a nutshell, if you could lay parts out on the floor for a H22 build, how would you go about it?
-Thanks for all your support.
Old May 18, 2009 | 04:59 PM
BBallz24's Avatar
Default Re: Suggestions For Build N Boosting H22s?
Darton MID sleeves if boosting more than 6 psi. Needed to run aftermarket pistons. I have CP pistons cause I got a hella deal on them. Same as my Eagle rods. It's not going to be cheap, so buy parts at a time. If you see a deal grab it and wait for something else to pop up.
Old May 20, 2009 | 09:10 AM
H22Accord_guy's Avatar
Your gonna have to sleeve the block for anymore than 6psi but if you wanna try it i dont recamend it but mahle makes cast pistons for the frm sleeves but alot of people had problems with them
Old May 22, 2009 | 10:08 PM
CD5_530's Avatar
get it sleeved it will save you $$$ in the long run
civic63
Jun 16, 2012 04:06 PM
accord387
Dec 30, 2005 08:55 AM
djnikko
May 14, 2005 01:00 PM
mtlmotorsport
Jan 9, 2005 11:22 PM
dennis
Sep 3, 2003 04:54 PM
