Wierd Oil on Plugs... (EM1-B16A)???
Old May 17, 2009 | 11:15 PM
rjmancia's Avatar
Default Wierd Oil on Plugs... (EM1-B16A)???
Well i checked my plugs the other day and they were wet with oil.... im thinking they are from the Gromets... but at the same time i dont.... the tip of the plug is wet when i took it out.. i dont burn much oil... and the car also doesnt smoke only when i get into Vtec it shoots couple small puffs but i heard its normal for a B16 to do that.. also i have Straight piping with an 8" Magnaflow Resonator... what could this be?
Old May 18, 2009 | 01:43 AM
waaBAAH's Avatar
Default Re: Wierd Oil on Plugs... (EM1-B16A)???
VTEC not vtech. you drive a honda..not a phone!!!
it isnt normal for any car to smoke but alot of hondas do smoke and those hondas that do smoke are still very reliable and can see plenty of more miles smoking.
as for the oil on the sprak plugs..
if the spark plug "wire" (top) area is wet..then yes it is the valve cover gasket grommets leaking.
if the electrode area is wet of oil (bottom)...then you have bad rings or low compression.
if the electrode area is wet of gas (bottom)...you have no spark or little spark or you were cranking the car way to long without starting
Old May 24, 2009 | 05:20 PM
rjmancia's Avatar
i see.... okay... well would the car smoke if the electrode is wet of oil??? just wondering??? cause it seems a lil wierd you know! lol... the motor only has 40,000 miles....
AudioFunk
Apr 16, 2014 09:24 PM
smetzger
Mar 31, 2008 10:15 AM
hbomb90
Apr 11, 2004 07:39 PM
VtecDA9
Apr 5, 2004 11:17 AM
Digital-R
Aug 3, 2001 11:07 AM
