What should I check when buying an ITR?
Old Aug 18, 2002 | 04:47 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default What should I check when buying an ITR?
It's a Black 2000 ITR with 16K miles. I have already seen it and I am taking it for a test drive early this week. Now, what should I have checked on the car?
I was planning on asking him to have Acura look it over and say that it has no problems along with a compression/lakdown test and clean carfax. Anything else that I should be looking for or having checked?
I just don't want to forget to check for something...
Old Aug 18, 2002 | 04:52 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: What should I check when buying an ITR? (ReBornGSR)
you can do the compression test yourself. I'd much rather take my car to a reliable H-tech member than to Acura...good luck
Old Aug 18, 2002 | 04:55 PM
Dc5-Power's Avatar
a 2000 itr with only 16k miles? that's pretty good.
Old Aug 19, 2002 | 04:14 PM
Majuniors_no_vtecfu's Avatar
Default Re: What should I check when buying an ITR? (kimchee_power)
16k?.....damn thats great
Old Aug 19, 2002 | 04:26 PM
George H's Avatar
Default Re: What should I check when buying an ITR? (Majuniors_no_vtecfu)
Its good, but my 2001 had half that when I bought it
But yes, take it to a local acura dealer and have them run an inspection on it. The inspection they do is exactly the same one they put used cars through before they sell them as "certified" used cars. It costs around $120 and is well worth it in my opinion. You will most likely have to pay for this, but if the owner still refuses to let you take it, even if you offer to pay, then I would consider not buying the car.
[Modified by KANJI, 5:45 PM 8/19/2002]
Old Aug 19, 2002 | 04:38 PM
Junglist's Avatar
Default Re: What should I check when buying an ITR? (KANJI)
But yes, take it to a local acura dealer and have them run an inspection on it. The inspection they do is exactly the same one then put used cars through before they sell them as "certified" used cars. It costs around $120 and is well worth it in my opinion. You will most likely have to pay for this, but if the owner still refuses to let you take it, even if you offer to pay, then I would consider not buying the car.
[Modified by KANJI, 5:27 PM 8/19/2002]
split the 120...if he is sure its in good condition he will gladly do it.
Old Aug 19, 2002 | 04:47 PM
OutLaw MR's Avatar
if its been in an accident I personally would'nt buy it if it has but thats just me
[Modified by OutLaw R, 1:47 AM 8/20/2002]
Old Aug 19, 2002 | 05:04 PM
check anything you can when buying a used car......but do you know what your checking?
Old Aug 19, 2002 | 05:36 PM
Bbasso's Avatar
rear tranny mount... they get loose and don't tighten back up
Old Aug 19, 2002 | 05:41 PM
Tommy_Gunns's Avatar
Default Re: What should I check when buying an ITR? (Junglist)
I doubt it. If I was the seller I wouldn't cover the cost of getting my car checked for the sake of someone else. But I would tell the buyer everything about the car including maintenance, how it was driven and accident record.
Old Aug 19, 2002 | 06:53 PM
George H's Avatar
Default Re: What should I check when buying an ITR? (Tommy_Gunns)
Thats true, the seller is under no obligation to split anything. Its the buyers responsibility to cover the cost of an inspection. Although, if the seller does not mind, then go for it, but dont lose a deal just because the seller does not want to cough up any cash for the inspection. Remember, the inspection is for YOU, not him, so that alone negates the fact that he should be under any responsibility to pay anything.
Old Aug 19, 2002 | 07:01 PM
JeffNA's Avatar
Knock of the body panels to see if the car has been in accident.
Check the underside and the crumple zones and the radiator support
Old Aug 19, 2002 | 07:21 PM
jond's Avatar
Acura should have service records on it. Make sure he's been changing the oil every 3 months.
Old Aug 19, 2002 | 08:42 PM
SurferX's Avatar
Default Re: What should I check when buying an ITR? (jond)
If we went by Acura's service records then half of us wouldn't have done any maintenance to our car ever...
Old Aug 19, 2002 | 09:24 PM
George H's Avatar
Default Re: What should I check when buying an ITR? (SurferX)
True. But if he takes the vin # to an acura dealer, they can tell him whether or not the car has had any warranty work done on it.
Old Aug 19, 2002 | 09:30 PM
Honda F1's Avatar
Always check the CV boots. They seem to always go bad on Integras.
LS Teg
Sep 1, 2007 10:45 PM
BrandonClaps
Feb 14, 2005 08:38 PM
jeremy.
Sep 14, 2004 10:45 AM
trainingday
Aug 22, 2004 08:16 PM
Black R
Aug 6, 2003 04:22 PM
