Please Help !!!
Old May 17, 2009 | 07:44 PM
90civicstdgold's Avatar
Icon2 Please Help !!!
Here is the scenario for the third time. I have a 90 std hatch, Its been swapped from a 4spd to a 5. I had truoble with the axels, so I bought ones that were 26 spline for a 5spd. Now they wont fit into the knuckles. Do I need new knuckles from a 5spd car, if so what car, si/dx/lx???. But on the other hand I have a complete suspension and a **** load of parts from a wrecked 90 Integra. Could i just use the knuckles from that or do I need bigger wheels. Right now the car has the 13inch steel rims on it. Someone told me I eed to go 14 or bigger. All advice would be apreciated,. I need to get this car rolling soon. Thanks
Old May 17, 2009 | 08:03 PM
D16SiHatch's Avatar
Default Re: Please Help !!!
I think you might be able to use the teg knuckles, but i'm not sure.. i'd wait for someone else to chime in on that. you need std/hf axles if you have an std/hf chassis. dx,ex,and si axles are larger at the hub. if you cant use the teg knuckles then either you'll need to get std/hf axles, or get dx/ex/si knuckles.
Old May 17, 2009 | 08:12 PM
i have the std axels but they didnt fit in the tranny which is out of a 90 lx. So i got the 5spd ones that fit the tranny. Now the problem is the knuckles
Old May 17, 2009 | 08:25 PM
D16SiHatch's Avatar
ok well i reckon that confirms my suspicion that the size is also different at the trans :/ lol. in which case since i assume replacing the trans is outta the question, you will need the appropriate larger knuckles.
Old May 17, 2009 | 08:29 PM
but if i use the integra ones will i need bigger wheels since the integra suspension has larger rotors doesnt it? or i would think so
Old May 17, 2009 | 08:36 PM
D16SiHatch's Avatar
Quite some time ago i remember reading about using integra knuckles, but i just can't recall if they are direct bolt on with no other fab, or what. you would imagine the rotors might be larger, but i'm not sure. i know somebody knows this info. you could try searching the forum for anything pertaing to integra knuckles? you might get lucky lol.
firejackal
Jul 12, 2012 10:11 AM
aznboi_2
Nov 3, 2007 06:12 PM
ceyazzie
May 22, 2007 10:20 AM
na91hatch
Jan 14, 2006 06:59 PM
RC_SKUBY
Oct 26, 2004 05:33 PM
