whizzzzzzzzzzzzzingggg alternator
Old Aug 18, 2002 | 04:26 PM
djay86's Avatar
Default whizzzzzzzzzzzzzingggg alternator
Ever since i got my car, b16 crx hf, the alternator seems to be pretty noisey. Its not noisy like the belt is loose, it makes just regular noise that other b16'ed vehicles dont. Its noisey. Its whiiizzzzzing. Does anyone know what im talking about.
It just now got pretty loose, I tightend it to the right tension, and its whizzing even worse now, in high RPM
Can anyone help me?
Old Aug 19, 2002 | 01:13 PM
djay86's Avatar
Default Re: whizzzzzzzzzzzzzingggg alternator (djay86)
ttt
Old Aug 19, 2002 | 01:14 PM
Urban Business
Guest
Posts: n/a
sounds like your actually turboed. anyway get some belt dressing on there see if that quiets it down. also alternator winds could be corroded and grinding on the houseing
Old Aug 19, 2002 | 03:36 PM
SOUTHCREX's Avatar
Default Re: whizzzzzzzzzzzzzingggg alternator (TorteX)
My alternator did the same thing, kinda sounded like a SC. After I swap motors I tried turning the old alt pully and I couldnt spin it by hand.
Old Aug 19, 2002 | 04:37 PM
djay86's Avatar
Default Re: whizzzzzzzzzzzzzingggg alternator (TEAM GARAGE SHIFTDOWN)
so what should i do?
Old Aug 19, 2002 | 04:39 PM
djay86's Avatar
\anyway get some belt dressing on there see if that quiets it down\
what is belt dressing?
Old Aug 19, 2002 | 04:43 PM
vtecrx's Avatar
could be a bad bearing. take it off and take it to autozone and get it tested. if it makes noise on the test bench then you might need to replace the alternator.
Andy
Old Aug 19, 2002 | 10:31 PM
SOUTHCREX's Avatar
Default Re: whizzzzzzzzzzzzzingggg alternator (vtecrx)
Belt dressing is just some **** you spray on your belts, keeps them from slipping and stops the sqweaking, its like armorall for your belts I guess. Take off your alternator belt and try turning the alt by hand, if it turns freely put the belt back on start the car and take off the positive battery cable and if the car dosent die then I wouldnt worry about it.
Old Aug 20, 2002 | 04:15 AM
2001civicex's Avatar
mine does the same thing. i am going to take a look at it today and see if i can spin it by hand.
Old Aug 20, 2002 | 05:36 AM
91CivicSi's Avatar
Mine was doing the exact same thing. The bearings in the alternator are toast. You can either have it rebuilt ($40-$50) or buy another one. I got a 90 Integra LS alternator for $30, problem solved.
Old Aug 20, 2002 | 08:12 AM
djay86's Avatar
Default Re: whizzzzzzzzzzzzzingggg alternator (91CivicSi)
Thanks man, and everyone else who helped. Does the LS alternator bolt right up? Any modifications needed? Thanks again.
Old Aug 20, 2002 | 07:36 PM
91CivicSi's Avatar
Yep, bolts and plugs right up. It was a tight fit with a 4th gen though. I had to unbolt my fuel rail to get the old one out and put the new one in. Other than that, no problems.
[Modified by 91CivicSi, 11:38 PM 8/20/2002]
rhys.l
Dec 7, 2012 10:07 AM
VTECth1s
22
Aug 31, 2006 05:26 PM
Integrity 19
Feb 18, 2005 04:10 PM
One8Hatch
Sep 25, 2001 05:33 PM
