really weird problem on b16a crx
Old May 17, 2009 | 07:34 PM
crxnatic's Avatar
Default really weird problem on b16a crx
for some reason the injector on cylinder 4 is not working. i checked for spark, i have spark. i replaced all four injectors, still have the problem. i used the noid lights to check for voltage on injector plugs.i have voltage on all of them except number 4 cylinder. so i replaced the ecu.still have the problem. i replace the injector resistor box , still have problem . tomorrow im going to check the wiring because to me thats the only thing left . if you please can help me try to determine or find out whats going on.by the way i have pr3 obdo ecu b16a
Old May 18, 2009 | 03:50 PM
crxnatic's Avatar
Default Re: really weird problem on b16a crx
anyone??????
Old May 18, 2009 | 04:05 PM
D16SiHatch's Avatar
you should see voltage from each injector clip, power from the res. box is always going there. what changes and actually makes the injector function is the ground that the ecu sends. so it makes most sense to me that the wire which controls the #4 injector is not making its way all the way back to the ecu for some reason. It should be a yellow wire at position A7 at the ecu.
Old Jun 5, 2009 | 10:05 AM
exist12's Avatar
distributor distributor distributor. I had a similar problem. Ask a buddy if you can borrow one just to be sure.
lsvtek
15
Jul 10, 2012 02:28 PM
V3locity
Dec 21, 2009 05:52 PM
sh!ft
Jul 23, 2009 09:04 PM
mickey b16
May 26, 2009 04:02 PM
mickey b16
May 18, 2009 07:33 PM
