Do i need camber kit for stock wheels+follwoing mods ?
ok i just want to lower my civic 1.5-2.5 inches with skunk coilovers on stock shock, do i need a camber kit for that ? and that on stock wheels ?
also if i install rear lower control arms aftermarket will i neeed a camber kit ?
thankyou
thankyou
i would install the parts and then see
its about a 50/50 chance.. some people get real bad camber wear from a 2" drop and some dont get any..
If you get real bad wear from a 2" drop, then your toe is out of spec.
Get an alignment and you'll be fine. Camber kit is not needed. Just be advised that your shocks are going to blow out quickly, then you'll have to redo everything, and get another alignment.
no camber kit needed. set toe to 0 or w/in factory specs. sometimes the factory shocks can take alot and will last a long time while being lowered on, and other times they wont last longer than a year.
exratedaccord93
Sep 8, 2006 06:32 AM
