Problems With My Camber Kit and Rubing
Hey guys I need some help. I hit a wall going around 30ish and bent my front lower control arm. Nothing else was wrong wit the car body wise. I replaced the front lca and everything seems fine beside when i go over bumps it makes a poping sound. I looked under by the shock and the camber kit is rubbing on the metal lip on the wheel well. My question is, Is something else bent or what is going on? Here are pictures of the camber kit. and the chipped paint on it. Thanks for all the help, let me know if i left anything out...
we had the same problem do you see whats hitting it you have to hammer it out ward to let the uca to move freely just cut out the rubber cover where you need to hammer you should be fine. cant believe you ran with that. good luck.
Should I hammer the whole lip or just the the area the camber kit is rubbing on? ^^^^^^^ Did your car ride fine after you hammered it out?
superhatchbackbros
Mar 20, 2007 01:43 PM
