oil burning question
Old May 17, 2009 | 05:17 PM
serr38's Avatar
Default oil burning question
ok so my im trying to figure out exactly what i need to fix.
my compression specs:
cly 1: 204
cly 2: 185
cly 3: 200
cly 4: 205
Leakdown:
cly 1: 82
cly 2: 88
cly 3: 88
cly 4: 88
Car Runs strong as hell. but its burning some oil. im trying to figure out if im looking at headwork...valveseals? etc? or bottom end. thanks.
Old May 17, 2009 | 05:58 PM
RockinaRHard's Avatar
Default Re: oil burning question
Originally Posted by serr38
Car Runs strong as hell..
so it burns oil... keep driving
Old May 18, 2009 | 10:28 AM
serr38's Avatar
thats what i was thinking
Old May 18, 2009 | 04:21 PM
dk127's Avatar
well, if your burning oil, you'll probably need new rings, plus that compression was a bit off. you'll need a rebuild.
how many miles are on the car?
Old May 20, 2009 | 08:13 AM
serr38's Avatar
engine has prolly like 85k on it. and one6 ILL garage and profunction told me the compression is fine and it prolly just needs valveseals and guides or a head rebuild.
Old May 20, 2009 | 05:55 PM
IBriaIN's Avatar
you're not the only one...my R burns about the same...and its really irritating, somedays I have to drive thinking if I have enough oil in my car. =(
Old May 22, 2009 | 03:03 PM
serr38's Avatar
this is how i drive everyday.
Old May 22, 2009 | 03:37 PM
Dogginator's Avatar
Daisy... Daisy...
It could be your valve seals too. Also, did you adjust the valves before the compression test?
Old May 22, 2009 | 04:07 PM
torneo sir-t's Avatar
New User
my teg us ta burn sum oil 2 did the valveseals and it help wasn burnin half as much oil after dat
Old May 22, 2009 | 05:38 PM
ITR-965's Avatar
Willing to bet that if you replace the rings and just do a nice hone job it will fix both the oil consumption and compression issues... It isn't expensive nor hard to do if you have decent technical skills.
GL with the fix
Old May 23, 2009 | 06:20 PM
serr38's Avatar
dont have the money for the rings i just bought this car. and no didnt have the valves adjusted
Old May 23, 2009 | 06:28 PM
racebum's Avatar
eventually you will burn a ringland or exhaust valve. just keep driving till you do & replace & rebuild once it blows.
it's probably ring related and if it were my car i would just do a hone with new rings n call it a day. new rings and valve seals do wonders to your average high mile b18c
Old May 29, 2009 | 02:42 AM
IBriaIN's Avatar
I'll keep what you said in mind...I have the money for it...but no time...Probably once I graduate school.
Old May 29, 2009 | 07:08 AM
99jdm_itr's Avatar
mine burns the same amount i just always check the oil . burns the worst in vtec tho
Old May 29, 2009 | 09:21 AM
itr#1334's Avatar
Nothing new. I do the same thing. I could solve the problem by not hitting v-tec but thats boring.
Old May 29, 2009 | 11:27 AM
99jdm_itr's Avatar
i think type r are the worste my friend has a py one and his burns oil just as bad as mine and he just rebuilt his not to long ago but me and him both have vafc 2 and once i put mine in thats when it really started smoking
Old May 29, 2009 | 12:45 PM
soulassassin13's Avatar
My car burn though oil, but runs like a West Virginian virgin, so I just keep adding oil. Planning on my rebuild next year.
Old May 29, 2009 | 01:15 PM
99jdm_itr's Avatar
mine to burns like a bitch but pulls like a champ
Old Jun 19, 2009 | 06:02 PM
serr38's Avatar
hmmm
Old Jun 20, 2009 | 07:26 AM
warwagon's Avatar
my old one used to use about as much as yours (actually looked like a mosquito truck going down the road), replaced rings and did a hone job, it quit burning oil after that.
Old Jun 20, 2009 | 02:03 PM
sti grip's Avatar
rebuild time !!!
Old Jun 20, 2009 | 02:08 PM
Si_chRis's Avatar
For the guys burning good amounts of oil, do you guys have your spark plugs fouling up?
Old Jun 20, 2009 | 02:20 PM
wrinkly's Avatar
my caR burns its fair share of oil and prior to this summer when i did maintenance after taking the car out of storage, i noticed that my old plugs had this weird white crusty buildup on them. best i can describe them is they looked like calcium deposites...however, none of them were oil fouled
Old Jun 20, 2009 | 02:25 PM
esco115's Avatar
I would check ur valves, valve seals, and piston rings... < follow the steps!
Old Jun 20, 2009 | 04:26 PM
Si_chRis's Avatar
Oh. Reason I ask is because I just recently had my head rebuilt on my EM1. All new seals, valve guides, valve seals and all clearances checked and were to spec on the valve seats and valves themselves.
But prior to the head rebuild, my car went through oil like crazy like you guys. And only one plug (cyl 4) kept getting that white crusty build up with black fouling. I thought the root cause were bad valve seals and guides.
But now with my rebuilt head, cyl 4 still gets the black fouling with the white crusty build up. Compression is fine across all four (200ish PSI) and the oil burning is about 1 qt every 2 weeks or about 500-1000 miles. So not too crazy as before.
I guess my oil control ring/ring land is busted in cyl 4 cause the block wasn't touched when my head got rebuilt (it was assumed fine, no scoring on the cyl walls).
