FS: H22 valve train BNIB and Throttlebodies
name fares
locale wilmington, nc
price make offers if not listed
paypal verified
BRAND NEW IN BOX DH valve train
new dh lightweight retainers, new design, coated
new dh springs coated 11k rev safely
new DH HIGH compression valves raises compression .5 without even doing piston change and shaving head great power adders for all motor h22's
DH-Racing not "rexthermal" is proud to introduce all-new unique true high compression racing valve design for the h22 prelude engine.
As some of you know, I dh racing have dedicated the last 15 years of my life to the Honda racing scene and have seen a lot of products and shops come and go. I have also, through the years, installed every type of racing valve made into the cylinder heads I port.
I have seen first hand results of what can happen when you install a valve made with poor grade materials and that is undercut too thin. In most cases, these valves stretch, flutter, and rock back and forth until they simply snap off - falling into the engine cylinder at a high rpm. This is called "dropping a valve". Once you have dropped a valve, the motor is usually garbage. Sleeves get destroyed, combustion chambers get mangled - there is nothing worse that can happen to an engine
NEW IN BOX DH 68-74 TB $200
NEW IN BOX DH 68-70 TB $150
DH-Racing Throttle Bodies bolt on in about 20 minutes.
This throttle body is brand new and is polished inside and out.
Looks similar to a "OEM" replacement Honda unit on the outside.
This stock outside look is great it will through off your competition.
Its a blind of OEM style stock sleek looks on the out side with the roar of a Lyon on the inside.
Perfect Modification For Anyone who wants a stock look and gain a big competitive edge over his or her competitors.
This Throttle Body will fit:
- D-Series: D16Y8, D16Z6 - B-Series: B16A, B16B, B18A, B18B, GSR, TYPE-R - F-Series: F22, F20C - H-Series: H22 - S2000 - many other applications.
paypal verified
