water drip under dash with air conditioning?
Old May 17, 2009 | 07:53 AM
tronic's Avatar
Default water drip under dash with air conditioning?
I've got an EG hatch (92 DX with AC) that's pretty new to me. Yesterday, hot day, running the AC a lot, noticed a water drip under the passenger side dash and some wetness on the carpet.
At first I suspected a heater core leak, but the coolant level was fine; the coolant was dark green while the drip looks like it is clear and doesn't smell like coolant at all, so I don't think that was it.
Is there anything in the air conditioning system around the glove compartment area that would cause condensation to build up and drip? That's what I'm hoping the problem is, but I searched and couldn't find anyone else mentioning that. I'm taking this car on a 2000+ mile roadtrip this week, BTW!
Old May 17, 2009 | 10:15 AM
JDMCRX's Avatar
Default Re: water drip under dash with air conditioning?
Check your evap hose. It may be pluged up.
There is a small 1/2" hose under the evap make sure it is not clogged or pulled out.
Old May 17, 2009 | 10:39 AM
gs_rbaby's Avatar
My thoughts exactly....
Old May 17, 2009 | 10:44 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Your evaporator (part of the A/C system) is mounted behind your glove compartment. The hose on the bottom is the evaporator drain hose. It exits the firewall through a grommet and drains outside behind the passenger wheel. As mentioned above, check that it is not blocked.
Old May 18, 2009 | 04:35 AM
tronic's Avatar
didn't know about the "evap hose", I'll try and find a parts diagram of where that is exactly and check it out.
thanks!
91DxRob
Sep 30, 2013 01:21 AM
Manny1987
Honda S2000
Dec 18, 2009 06:24 AM
swapdohc
Jul 14, 2005 11:13 AM
Jet Black
15
Dec 12, 2004 01:57 PM
GTScott
Feb 2, 2004 07:32 PM
