first gen obd0 b16 iacv
Old May 16, 2009 | 11:22 PM
DVS_SI's Avatar
Default first gen obd0 b16 iacv
I need to know what iacv will fit the first gen b16. I have to order it from Honda and it is a special order non returnable part. Dont want to have to buy more than one. Pics of part below.
Old May 17, 2009 | 01:08 AM
streaker's Avatar
Default Re: first gen obd0 b16 iacv
Try these guys for genuine Honda parts at good prices. ( I am nothing to do do with the company, just we in the UK are very happy with the service and parts)
admin at autodynamics-honda. com
Have you cleaned the IAC very well and sprayed loads of lube spray in there, then tested it? Usually works.
If you get really stuck, PM me and I should be able to find you one in England.
Old May 17, 2009 | 07:41 AM
jlicrx's Avatar
it is the same as the 88-91 CRX/Civic Si D16A6
Old May 17, 2009 | 10:58 AM
DVS_SI's Avatar
Thanks, two forums and the same person answers both. What are the odds?
Old Jun 25, 2009 | 05:08 PM
thid92's Avatar
can I haz?
how did you go about ordering this part and from where. A regular honda dealer?
Old Jun 25, 2009 | 05:46 PM
D16SiHatch's Avatar
apparently pretty high lol
Old Jun 26, 2009 | 07:54 AM
thid92's Avatar
can I haz?
also 1st Gen CR-V uses the same IACV.
Old Jun 26, 2009 | 11:39 AM
michael O's Avatar
I'm pretty sure I have used one from a d15b, a b18c, and a b18a1.
I'm pretty sure they are all standard but I'm not sure. I had a lot of parts lying around while I was trying to fix my idle problem.
Old Jun 26, 2009 | 02:19 PM
thid92's Avatar
can I haz?
yes you could use the one from a B18 but the water hook up has a bend on the passenger side, no big deal. That is the only difference that I have seen.
Dforce
Oct 13, 2006 07:17 PM
theslugbug
Oct 30, 2005 01:25 AM
SpeedMonkeyRacing
Oct 7, 2002 04:32 AM
