clutch cable
Old May 16, 2009 | 11:12 PM
be8teensee1's Avatar
Default clutch cable
anyone ever do a auto to manual swap on a crx the had no factory hole for the clutch cable to feed threw the fire wall?. i have read alot about it and every one i read says there is a hole there (filled with a gromet , but the one im working on doesnt have one. ... any suggestions
Old May 16, 2009 | 11:16 PM
89s1's Avatar
Default Re: clutch cable
ummmmm drill a hole?
use a grommet to keep things from chaffing....
srsly?
Old May 16, 2009 | 11:34 PM
uhmm i did drill a hole but what does the actual metal part of the cable go into ? the hole is for the gromet , im talking about the hard metal part of the cable it has to hook to somthing or the cable will just pull threw the firewall. is there a bracket that maybe mounts to the pedal assembly to hold the hard part of the cable
Old May 16, 2009 | 11:38 PM
btw car is an 88 crx dx auto ,
Old May 16, 2009 | 11:48 PM
going to bed bump
Old May 17, 2009 | 08:46 AM
I CRX I's Avatar
srsly?
yea.... dont listen to this guy... drill a hole, use a very thick plate like one of your tow hooks to run the cable through before the firewall as the firewall will break, hook the cable to the pedal and adjust. i repeat, the firewall will rip like foil in time if its not braced well.
Old May 17, 2009 | 10:47 AM
efjones9's Avatar
just look at a manual crx and see how its set up but I CRX I is right brace that firewal good cuz it wull rip and bend
Old May 17, 2009 | 09:18 PM
thanks i crx i i did just what you said , the clutch works great. now i just have to see what throttle cable to run
Nathaniel Corum
Nov 2, 2014 01:52 PM
kricket3000
Sep 15, 2009 11:44 AM
ryanevansoh
Mar 23, 2009 02:02 PM
EKIM NART
Mar 12, 2006 06:06 PM
5litereater
Jun 14, 2004 01:55 PM
