Classic Hondas All Pre-1988 Hondas.
Miata wheels on CRX
Old May 16, 2009 | 04:55 PM
ZUL8R's Avatar
Default Miata wheels on CRX
I got a set of 14x6JJ miata wheels 10.4 pounds. they seemed to not fit right on my 86crx si.. hmmm
Old May 16, 2009 | 06:03 PM
ZUL8R's Avatar
Default Re: Miata wheels on CRX
dremel.....
Old May 17, 2009 | 02:02 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Your problem is that the center hole ID of the Miata wheels is (I think?) 54.1mm and the center hole needed for the CRX is 56.1mm. Your options are to 1) take your Miata wheels to a machine shop and have them increase the center hole ID to 56.1mm while keeping the same center location so they will be hub-centric, 2) finding something like a very small ridge reamer for lawnmower or moped engines and reaming out the center hole to about 56.1mm yourself, by hand, and hoping that the center axis doesn't drift too far off in the process, or 3) using a dremel/holesaw/hacksaw/blow torch/hammer/some other tool to crudely enlarge the hole yourself to larger than 56.1mm and using the wheels as lug-centric wheels. Honestly, IMO option 1 is the only decent one. Everything else will most likely end up being half-assed butchery that ruins the wheels. Just sayin'
Old May 17, 2009 | 03:52 PM
E-AT_me's Avatar
you can run a spacer that pushes them out past the bore.
Old May 17, 2009 | 06:23 PM
ZUL8R's Avatar
where do i get the spacer?
Old May 18, 2009 | 05:17 AM
cbstd's Avatar
When you buy the spacers (any decent parts store) be sure to also price a set of bearings as you will put extra strain on your wheels bearings and they will eventually fail.
It is so much easier to use the correct wheels on your car.
Old May 21, 2009 | 08:47 PM
ic's Avatar
ic
I've been running miata wheels on my 94 civic for 3 years. I dremeled them out freehand. they ride perfect. what's the problem?
Old Oct 21, 2009 | 12:21 PM
Davidss's Avatar
Bump! I have miata wheels and just used a grinder. It did take a while...
Old Oct 21, 2009 | 12:50 PM
E-AT_me's Avatar
bump! i used a 2 1/4 hole saw! worked quick and effective..
Old Oct 22, 2009 | 01:11 PM
ian1006's Avatar
I have never heard of spacers putting stress on your wheel bearings...care to explain with evidence?
I agree with doing it the right way. I have seen a lot of Miata wheels on Hondas and they look great.
Old Oct 22, 2009 | 01:57 PM
blasterman87's Avatar
a good tool would be a cylinder hone. i have one i use for rebuilding 2 stroke engines and seems that it would work fine
Old Oct 22, 2009 | 03:09 PM
turnofftheradio's Avatar
by pushing the center of the wheel out past its original location, the outside bearing gets more weight put on it. think of it like a lever with the bearing being the fulcrum. essentially you are creating a longer lever, putting more force on the bearing. a funny offset wheel does the same.
Old Oct 22, 2009 | 07:47 PM
ian1006's Avatar
Ahhh ok, thanks for the education!
Old Oct 23, 2009 | 01:32 AM
E-AT_me's Avatar
but the whopping 5mm spacer is not going to put barely any stress on your wheel bearings.. sticky tires would put much more stress on your wheel bearings than just spacing them out the required 5mm..
Old Oct 23, 2009 | 07:03 PM
2ndGenGuy's Avatar
I concur, you'll be fine with wheel spacers.
LM1092
Jan 11, 2013 10:03 PM
royzacsdad
May 4, 2012 12:58 PM
bonus12
Nov 14, 2011 07:45 PM
teh_pledge
May 14, 2011 07:31 AM
92jdmhatch
63
Feb 6, 2004 12:02 PM
