Wat clutch kit and flywheel to use? Searched
Old May 16, 2009 | 04:12 PM
Jonny Rocket's Avatar
Default Wat clutch kit and flywheel to use? Searched
Okay I have a 1990 civic hatch DX. 94' LS long block and Im going to install a S1 B16 cable trans which I believe has 24 splines. I just wanna know what clutch kit to use and what flywheel. Thanks and I did search but the answers were not clear
Old May 16, 2009 | 08:05 PM
powerpro_69's Avatar
Default Re: Wat clutch kit and flywheel to use? Searched
should be a 90-91 integra and b series flywheel will work
gripforce-clutches on ebay will sell u a nice combo pack pretty cheap
Old May 17, 2009 | 09:02 PM
Im just tryin to be sure as to what year clutch kit to get. I heard the 90-91 are the small spline, I could be wrong...Thanks anyway
Old May 18, 2009 | 05:32 AM
dephtone's Avatar
Yes the 90-91 is the small spline and 92-93 is the large spline. When I was buying a clutch for my b16 trans they had said the best way to find out which size shaf tyou have is to get a 90-91 integra clutch alignment tool, put it in the clutch if it's too small, then you know you have to get a 92-93 integra clutch disk set.
I would recommend the Exedy and fidanza flywheel combo. ~300 bucks (IIRC) for OE replacement clutch that has proven it's worth as well as a good flywheel. I have seen others use gripforce and xtd etc but I'v heard ups and downs of both. Good luck on your selection!
Old May 18, 2009 | 07:04 AM
So lets say Im supposed to get the 92-93 clutch kit..I need to get the flywheel for the same year too right..Yes Im definetly going for the exedy/fidanza combo. Thanks dephtone
Old May 18, 2009 | 09:03 AM
Furyof4's Avatar
S1 trans is SMALL spline. Get a 90-91 clutch like said. All b series flywheels are the same though.
matt's hatch
Jan 30, 2010 06:03 PM
AllMotorRandy
Jul 13, 2009 10:49 AM
Origin
Sep 11, 2005 08:00 PM
redlineh22a
Feb 20, 2003 08:46 PM
90-CRXSi
Oct 10, 2002 01:25 PM
