toda specA on stock ecu?
Old May 16, 2009 | 01:52 PM
danny98r's Avatar
Default toda specA on stock ecu?
im pretty much turning my car back to stock specs. i did end up selling my stock cams so is it safe to run toda specA's on my stock ecu. the cams will be set at 0,0. it doesnt make sense to me to buy a set of itr's when the todas are mild anyway. im still using stock type r valvetrain. will i lose hp with this setup? im thinking that i will end up increasing some hp cuz the cams are a lil more aggressive. should i change them back to oem? thanks..
Old May 17, 2009 | 06:08 AM
H-PIMP's Avatar
Default Re: toda specA on stock ecu?
Were you running more aggressive cams on the stock valvetrain before? Or are you re-installing a stock head?
Under normal circumstances, A's will work fine with the stock ecu/redline and stock valvetrain. There is some power to be made with them if the car is tuned.
Old May 17, 2009 | 07:44 AM
danny98r's Avatar
the head was stock before. i just switched cams . will there be a power increase with no tune with toda a's on a stock ecu? for ex: bone stock type r with "just" toda spec A's..
Old May 17, 2009 | 06:01 PM
mist sITR's Avatar
as far as i've heard you'll be fine.
wish i could find a used set.
if you end up wanting to swap them back for stock. i'd think about tradeing.
Old May 19, 2009 | 12:16 PM
Black R's Avatar
25 Year Member
they are fine. i've done that before with bolt-ons. toda a's, i/h/e, vafc and stock obd2 ecu = good stuff. tuned is even better, but they won't hurt anything even with stock valvetrain and stock ecu running them.
i'm currently using them in my itr with a 20g turbo and 10-12psi of boost.
M2S~Jaime
Nov 12, 2009 07:31 PM
Anone
Aug 2, 2004 01:21 AM
Hard2Find
Sep 23, 2002 12:03 AM
typevimports
Jun 26, 2002 05:43 AM
