Suspension & Brakes Theory, alignment, spring rates....
just got alignment done now 1/2sec delay
Old May 16, 2009 | 09:42 AM
es.roadster's Avatar
Default just got alignment done now 1/2sec delay
my car is a 90 civic hb, koni/gc (cat about 3 inches off the ground; slammed-ish?
195/55/15 s.drives.
well before the alignment, i had a "stiff" steering feel. i loved how it handled and i just felt that i had more control.
just yesterday, i had my alignment done ( same height, didn't adjust anything btw ).
now the "stiff" feeling isn't there anymore.
does anybody here in h-t know what i mean? and why my car slops now after alignment?
Old May 18, 2009 | 01:59 PM
Pinja's Avatar
Drunk Wagon Pilot
Default Re: just got alignment done now 1/2sec delay
Take it back to the shop and make sure they tightened everything back up.
Old May 18, 2009 | 02:49 PM
Tarmac Junkie's Avatar
The way I read this, you took it to get an alignment, and it dident need any adjustment at all. So they dident change anything. If all was in spec they proobably just checked it.
Old May 18, 2009 | 10:43 PM
no! haha
i meant i didn't adjust my ride height at all.
the guys are the shop aligned my car to factory specs.
after the alignment, i didn't feel that "stiff" feeling.
found out the stiffness was caused by toe out.
anymore tips to make my car ride smooth would be greatly appreciated.
Old May 18, 2009 | 11:23 PM
Getting the car corner weighted will also improve the feel of the car when you drive it...
Old May 23, 2009 | 06:05 PM
do you mean corner balancing? if so, i'll go back and get it done.
but before i do that, i will raise my car about an inch or so.
Old May 23, 2009 | 09:29 PM
Tyson's Avatar
what does the print out say? can you scan it?
no, a corner balance is not going to do anything like you are looking for.
seems like your ride went from crappy to better, but you just liked crappy better. i wouldnt consider "stiff" steering as desirable.
Old May 24, 2009 | 01:02 PM
i'll get the scan sometime soon. left the printout in my friends rex when i went fishing.
tyson, is there a tension adjustment on our EF"s? i also posted in the auto x section. and thats what i got from a user.
Old May 24, 2009 | 06:49 PM
Tyson's Avatar
yeah, there is the big nut at the pinion. its usually not adjusted during an alignment. but maybe the tech didnt like your stiff steering.
es.roadster
May 24, 2009 01:00 PM
vladd
Suspension & Brakes
May 12, 2009 11:31 AM
Kangolbrand
Suspension & Brakes
10
Nov 28, 2006 09:23 PM
LoseRPunKx182
Aug 2, 2005 11:03 AM
alfaaay
May 7, 2003 01:25 AM
