Spray Painted Hood results bad
Old May 16, 2009 | 08:12 AM
91EF919's Avatar
Default Spray Painted Hood results bad
Ok i was redoing my hood, i sanded the whole hood down till i saw metal. I got black primer, spray painted that one and it look nice like that, because i wanted to get a flat black look. But i had some flat black paint so after like 20mins i started to spray that on. And the final results was horrible all i see it my spray painted streaks. and some parts are like more darker then the other. So what should i do sand it again, and forget the primer and just put the flat black paint on. Or just sand it and just primer it again?
Old May 16, 2009 | 09:59 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: Spray Painted Hood results bad
Cross posting in both CRX subforum and here? tsk tsk...
Old May 16, 2009 | 10:41 AM
m00nr0ck Si's Avatar
ditch the spray paint and get a gun.....the results will amaze you
Old May 16, 2009 | 12:31 PM
Eyger's Avatar
Yeah, the only real way to get good results would be to use an HVLP gun or similar. IF you MUST use a spray can, you should sand it down again back to the primer then wipe it up and prep it, then shoot the paint out of the can, and make sure it goes on wet, leading with a wet edge as you spray, have a friend shake a can of paint while you paint and switch cans with him every so often.
Old May 18, 2009 | 01:09 AM
ej1Squad's Avatar
Best advise for you .
This is my car and it was done at my shop .
This the Base coat gun and not sanded yet .
is that what you are looking for ?
this is what it looks like now
well im just showing you how using a gun makes a difference .
Old May 18, 2009 | 07:44 AM
xxfile's Avatar
I'm just curious: what guns (relatively economicly) would you guys suggest? I just got laid off and so I will have time, but won't have a lot of money
91EF919
18
May 18, 2009 08:22 AM
19integra94
Dec 6, 2007 04:41 PM
sixfiveoh
Jul 7, 2006 02:43 PM
Agent_STFU
Aug 19, 2005 07:20 PM
TypeR 599
Feb 8, 2002 02:57 PM
