rear disc on a 4 door.
what would be the best car to get rear disc off of for my 4 door. i helped a friend along time ago and he used crx rear disc on a 4 door but the e brake cables were way too short. so what e brake cables do i need? do i need the prop valve? ive read on here you dont need it. anything else i will need? and whats the average price for both sides from a picknpull place? i was thinking of getting it off a 4 door da integra for the right cables?
The CRX cables are the shortest. Any other cables should work. I paid $180 for the rear trailing arms complete with sway bar and sub frame for my accord. Basically I go everything for $180. The prop valve will help with the rear floating when you slam the brakes. The stock one will work, but if you slam the brakes the front will lock up and the rear will not. So the *** end of the car will float left or right.
