DPFI to MPFI issue.
Hey guys, I finally got around to going MPFI on my STD Hatch. It runs great, not throwing any codes but.. it starts really, really rough. I got all my parts for the swap off my friends running Si. When it starts, it's almost like it's starting off 1 or 2 injectors. If I give it a little gas as it's stumbling to start it fires right up and runs just fine. I tried switching the two white wires on the dizzy, but that makes it not start at all. Any ideas?
The car is an 89 STD with swapped D15B2, MPFI parts from 91 CRX Si.
Been messing around with it, making sure all the connections are nice and, well, connected. The idle is kind of erratic from 1000-1500, I'm thinking the IACV is dirty or something. The one I put on was from a junk yard and I got it ~3 years ago, didn't even think to re-clean it before installing it. Once the car cools down I'll take it off for a nice cleaning. Any other input is much appreciated.
Heh, thanks. I cleaned my IACV, it was a little dirty. It idles a little better and doesn't stumble when I'm barely giving it gas anymore, but it still starts really rough. The idle is erratic at ~1100-1500 as well. Anyone have any other ideas? Pretty stumped and I have a big drive coming up in a few days, I'd hate to break down 700 miles away from home :S
my buddies ls does the same thing. if i were u, id try to get a iacv off a car u kno starts and idles correctly because the seals(fergot the "correct" term) only last so long clean or dirty. the only time this will cause problems is idle and starting up
remember the car is almost 20 years old
id also check the timing with a light but if ur sayin full power through the power band id doubt it.
Don't mind the wires, I'm nowhere near done cleaning it up. Just making sure I get it running the way I want before I loom everything.
fitv's were not available until 92. 88-91 civic/crx's only had iacv's, and you should have no trouble getting it to idle properly. assuming vaccum lines are all snug and routed properly, and no vac leaks. it is possible that the seal between the iacv and IM is leaking. i had to replace it because i was getting a surging idle after swapping to an xspower intake manifold.
i had the same problem when i did my obd-0 to obd-1 swap, IT DID THE EXACT SAME THING, try switching the plug in for the evap purge solenoid and the tps, i'm willing to bet money thats what it is
redlines:
1st: 30
2nd: 65
3rd: 75? it wouldn't rev higher than that for me
4th: 90? wouldn't go higher than 4500
