EM1 fog lights
Old May 15, 2009 | 07:54 AM
Kaotyk's Avatar
Default EM1 fog lights
So my friend and i just put on some fogs on my em1, took us a while to drill those holes to fit on the bumper. It's a OEM bumper but the wiring is a bit weird. So according to the "famous" online fog lights installation, the 1 pin connector (brown color head) should connect to the one with the "blue tape, next to the windshield wiper" plug, but BOTH of the 1 pin connector heads are the same. Both male no female, if u know what I mean. I tried to look for another plug to go in but all these research that plug is still the right one.
"the other side to the brown connect thing is near the windshield washer fluid thing. the ground in anywhere."
The problem is, this "other side to the brown connect thing" is the same exact as my 1 pin connector head
Here's where the problem is from the installation guide.
If you know what is wrong with this, please reply asap! I really appreciate it everyone.
_K
Old May 15, 2009 | 08:24 AM
bmoua's Avatar
Default Re: EM1 fog lights
basically delete that brown connector that routes to the engine bay. Just make sure to plug the other brown plug that routes to ur interior fuse box( or what ever that's called). The purpose for the interior brown plug is to light up the switch, the exterior brown plug is there so u can wire ur fogs to ur aux/headlights when u turn them on. I prefer having my own switch for the fogs, also the instructions they give u is for a oem setup, not the replica setup.
I'm guessing u bought the replica fogs correct?if so all Ull need to do is wire up the switch so it has ground/power then wire the main power to ur battery and ground. I'd check the wiring to to ur relay switch as well. On almost every replica fog light setup I've seen the wiring is always wrong. I have 3 years experience with replica fog lights haha trust me.
Old May 19, 2009 | 05:37 AM
Kaotyk's Avatar
Haha I got it to work, thanks man!!
Gant
Mar 3, 2009 08:02 AM
1jdmek
May 21, 2007 11:22 PM
GraphiteMW
Mar 7, 2007 02:10 PM
Eclpze97
Jul 27, 2004 10:51 AM
Surreal
Mar 14, 2004 09:14 PM
