need help
so i just recently did a headgasket swap, i put everything together and when i go to start it, it sounds like a subaru and its running really rich and the spark plugs are really black. any diagnosis?? help plz?! lol thanx in advance
thanx ima check it. its bad and yaa i got da fpr hooked up, how would you recomend timing it? the way i did it was put a screwdriver in the #1 and #4 spark plug hole and i got it to tdc then lined up the cam then put the timing belt back on, its a sohc btw
danwants2btheman
Jun 3, 2007 11:45 AM
