Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Wheel stud removal on SI
Old May 14, 2009 | 04:48 PM
ajpturbopittsburgh's Avatar
Default Wheel stud removal on SI
Has anyone tried to remove the wheel studs? How much did you pay? Did you do it yourself? I attempted to do replace them but they won't clear the inner hub. Do you need to separate the wheel bearing from the axle flange? I am doing this to put on H and R wheel spacers.
Old May 14, 2009 | 05:24 PM
i-VTEC_DOHC's Avatar
Default Re: Wheel stud removal on SI
thats what midas is for
Old May 14, 2009 | 05:30 PM
RICO_'s Avatar
NO MERCY!
Just get a turbo
Oh wait.......................
Old May 14, 2009 | 05:31 PM
I hate midas, minike, monroe! haha. My honda dealer is gay sometimes, They told me they won't modify a car under warranty and I said I have no warranty because I am boosted. I said I don't care about the warranty just charge me for the job I want you to do and they said they wouldn't unless they were broke.
Old May 14, 2009 | 05:32 PM
Originally Posted by RICO_
Just get a turbo
haha
Old May 14, 2009 | 05:36 PM
RICO_'s Avatar
NO MERCY!
My dealership just has you sign a statement stating that there will be no warranty on any aftermarket part of labor performed on that part....and then they'll do the work.
Old May 14, 2009 | 05:43 PM
well u cant use any house tool to pull out a wheel stud. theres a special press i've seen that makes it real simple. just go to midas. stop being scared or whatever. they have waranty on their work so if anything goes wrong, they'll cover it.
Old May 14, 2009 | 06:49 PM
ironworker's Avatar
If its anything like the older civics take a hammer and bust it loose then take the hub off (if thats what you call it) and remove stud. Replace and beat it back in.
Old May 14, 2009 | 07:18 PM
It's not.
Old May 15, 2009 | 01:16 PM
ChargedSI's Avatar
I had mine replaced with longer studs. They did it the same time they installed my Brembo's. The HFP rims would not clear the Brembo's without a 6mm spacer. With the spacer, the studs were too short. They had to pull the axles and replace the wheel bearings to do it. Cost me about $650.00. Still cheaper than replacing my brand new HFP wheels.
Old May 15, 2009 | 04:12 PM
Thanks charged. That's what I didn't want to hear but that's how I thought you would have to do it since the studs won't push past the inner hub. It's ashame the flange it's a little bit bigger but I guess that would change the bolt pattern.
Old May 15, 2009 | 06:39 PM
clemsonhatch's Avatar
I haven't looked at the 8th gen. But on my integra spindles I ground just enough metal off to push the wheel studs out and get new ones in without having to press out and replace the wheel bearings.
Old May 15, 2009 | 10:54 PM
dont forget when you get extended studs, its recommended that they are tack welded.
Old May 16, 2009 | 07:25 AM
Why, that doesn't seem right. Then it would more difficult to get them off
Old May 16, 2009 | 08:59 AM
do u know what a tack/spot weld is?
and dont ask me.
http://www.jhpusa.com/store/pc/viewP...idproduct=1534
http://www.jhpusa.com/store/pc/viewP...idproduct=1931
oh and for the record, the skunk2 extended wheel studs have been discontinued.
Old May 16, 2009 | 10:56 AM
and dont ask me.
You get appropriate length studs whith H & R spacers.
And i-vtec you shouldn't go there. I am actually a welding inspector so I will not ask you. And yes it doesn't seem right. They are not tack welded by honda. And if they were they would even be harder to get off. You would have to to get a little burr grinder or angle grinder to remove the weld or beat the studs even harder to break your little tack weld. The lug nuts pull the stud into the back of the axle flange and are held by the lip on the stud.
I would not reccommend putting the heat produced by your tack/spot weld onto the flange and risk warping it and making your wheels not seat properly on the flange, that may be extreme and may not happen I'm just saying. And the localized heat near the the wheel bearing, cooking the grease may not be good either.
Old May 16, 2009 | 11:42 AM
my friend didnt tack weld his and his stud broke.
i had mine tack welded on my old 4dr ej and they were fine.
you just have to do it right.
Old May 16, 2009 | 12:06 PM
Sounds more like a defective stud possibly. Where did it break at?
Studs, as long as they are high quality should be forged. It is typically not reccommended to weld repair or weld on a forging. If you do weld on a forging what you effectively do is heat treat the material in a non uniform fashion which may actually weaken the material at the transition of where the weld metal meets the base material, possibly causing a fatigue crack.
Pre-heating prior to welding would help but you still have a difference in material with different physical properties which would be a less than ideal situation on parts that are load bearing.
Old May 16, 2009 | 01:24 PM
tomh1979's Avatar
i noticed one day while looking at the parts catalog for the Si, that honda also offers a longer wheel stud from factory, well as a replacement, not really sure why they did that.
Iloveyourhonda92
34
Jun 9, 2010 11:31 PM
John 07
Jun 26, 2008 11:33 AM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
Pompiuses
Sep 12, 2005 06:57 AM
