d15 to zc swap question
Old May 14, 2009 | 03:21 PM
miguey310's Avatar
Default d15 to zc swap question
hey every 1 well as the titles says i gonna get a dx and i wanna do a zc sohc swap and wat do i need 4 the swap beside the engine ??
Old May 14, 2009 | 04:09 PM
black0hatch's Avatar
Default Re: d15 to zc swap question
convert to mpfi ecu and dizzy for the new motor probably more stuff too
Old May 14, 2009 | 06:44 PM
miguey310's Avatar
some zc come with dizzy and intake manifold can that work??
Old May 14, 2009 | 09:02 PM
miguey310's Avatar
need help
Old May 14, 2009 | 09:57 PM
thisiskev's Avatar
go to fourthgenhatch.com it has a dual point to mpfi info. everything else should just bolt up. and if you didnt want to switch to mpfi you could just use your same d15 parts and put them on the zc. but i would recommend doing the little extra work for the extra HP.
Old May 14, 2009 | 10:13 PM
miguey310's Avatar
yeah im gonna do the mpfi swap but when i buy the zc it come with the dizzy and the intake manifold will it work??
Old May 14, 2009 | 11:10 PM
crex23's Avatar
Yes it will work fine, but make sure the motor you buy is OBD0.
I also used the guide from fourthgenhatch.com to do my MPFI swap. It has excellent detailed info and pics, and it lists all the things to do the swap.
Old May 16, 2009 | 01:28 AM
Baserloks's Avatar
i have the complete zc sohc motor for sale...click on my thread below...located in Riverside,CA
http://www.hondamarketplace.com/show....php?t=2559899
dmunoz
Aug 27, 2010 07:21 AM
osmbr
33
Jan 15, 2010 05:10 PM
myJDM89EF
Sep 12, 2005 11:05 AM
contender
Jul 2, 2005 08:14 AM
