FS: EVO 8 2.3 stroker built longblock FS
Ok guys well I thought I would throw this on here as well as the other sites I have it on.. This is a Full Evo 8 Longblock stroker motor.. The following is done to it.. Can also have full engine harness if buyer wants.. comes with ac compressor,ps pump.. Im missing stuff on this so once I remember it I will add it.. Ill throw some pics up but the power is inside this beast lol.. I also have a cusco twin disc for sale.. The motor has 1700 miles on it mostly all highway and some dynoing.. Never past 23 psi on my 35r setup and this thing was scary.... So want that summer upgrade this would be it.. Im just hoping to pass this along to someone on here or someone that has a buddy with an EVO.. this is out of my 2003 EVO 8 GSR.. The build was done around 32XXX miles and I pulled it around 33750 so this was ran only during one summer.. So any questions please pm me.. I have alot of money into this as you can see.. It was built by Buschur Racing as you can see alot of the parts are theres..
Thanks
2.3 Buschur stroker motor shortblock 3550.00 NEW
Stock Head no head work or anything..
Buschur BF 272 Cams $600.00 NEW
Buschur Valve springs and Retainers $300.00 NEW
Brand NEW OEM Headgasket
Buschur Ported intake manifold
Buschur Ported Throttle Body
ARP Headstuds
Kevlar Full Belt KIT $300.00
Aem intake mani sensor for EMS
The only thing I would recommend on this is just getting all new seals/gaskets with this built *** motor before you put this in otherwise needs nothing but oil and a nice turbo for some crazy power.... So im taking offers on it and I can also do a deal with the twin disc if need be or that seperate.. That also only has 1700 miles on it.. no launches or anything.. Then have a stock transfer case also..
Thanks
ARP Headstuds
The motor is pulled out of the car and avaliable for pickup.. Can also meet..
I will not part out anything on the motor it all goes as one..
stroker motor consits of
Bearings (Rod, Main and Thrust)
Balanced, turned & polished Crank shaft
Buschur Racing Balance Shaft Eliminator kit
ARP Fasteners *does not include head studs) which i have the headstuds
BR Spec Crower Connecting Rods
BR Spec JE Tough Skirt Coated Forged Pistons
Compression Ratio: 9.0:1
