depin A22 when using aem ems? OBD1
Old May 14, 2009 | 12:40 PM
RACEPAK's Avatar
Default depin A22 when using aem ems? OBD1
hello everyone,
i just got a aem ems and i saw on ffsquad site that it is needed to depin pin A22 (ICM) from the connector.
can anyone confirm it is required? heres the link :
http://www.ff-squad.com/technet/wiring.obd1.htm
thanks
Old May 15, 2009 | 06:31 AM
sander's Avatar
2.7(p/t)
Default Re: depin A22 when using aem ems? OBD1
Look in your installation instruction file for that particular ECU. I believe the big old 1000 boxes needed something like that done.
Old May 17, 2009 | 03:12 AM
RACEPAK's Avatar
well i looked at the manual and it says nothing about this pin, on the other hand you can see in the diagram that its not "dedicated"
http://static.summitracing.com/globa...vm-30-1040.pdf
thanks for any help
Old May 17, 2009 | 07:18 PM
baller status's Avatar
Well just de-pin it whether to be safe. I'm not sure whether the newer boxes require it either, but it's very easy to de-pin, and it's not necessary for either the stock ECU or the EMS.
Have you even checked whether your harness has that pin there?
Old May 17, 2009 | 09:31 PM
RACEPAK's Avatar
sure, it has it,
G-power
Jan 27, 2014 10:08 AM
rallystyle
Jul 3, 2007 12:46 PM
miller
Sep 2, 2002 06:40 AM
