Vtec change over RPM
Old May 14, 2009 | 12:14 PM
Creator's Avatar
Default Vtec change over RPM
Tried the search...oddly enough had no luck with it.
Does vtec kick in on a type R at the same time aa a GSR?
Is this also true for a 98+ JDM type R?
I have a LS-vtec that has a 01 GSR head and 98+ JDM type R cam. The tuner has it switching over at 5k and it instantly drops about 10 HP and doesn't get back to where it was until 6k. In the car it feels like a long studder and once it hit's 6k it takes off. I know the obvious solution would be to make the change over later but I wanted to know how it was from the factory.
Old May 14, 2009 | 04:21 PM
dk127's Avatar
Default Re: Vtec change over RPM
ITR = 5700 RPM
I'm not sure about the GS-R, but I believe that it has a 2 stage deal with the VTEC then the intake.
Vtec at 4400, and secondaries on the intake at 5700 or 5800.
Old May 14, 2009 | 06:40 PM
Creator's Avatar
Thanks, I appreciate the info. Probably why I lose HP when it kicks over....cams aren't geared for the lower air flow.
Old May 15, 2009 | 10:06 AM
Creator's Avatar
Can anyone else confirm this? Just want to be sure when I call up the tuner to blow his ears out.
Old May 16, 2009 | 02:26 PM
b19coupe's Avatar
ITR VTEC = 5,700. Confirmed.
Old May 16, 2009 | 02:45 PM
VTECROAR96typeR's Avatar
Originally Posted by dk127
ITR = 5700 RPM
yup that sounds about right
Old May 18, 2009 | 06:56 PM
jdm95gsrteg's Avatar
Gsr has two stages 1st stg at 4400 you cant hear this one but when the secondary comes in at 5700 rpms hold on haha jk
Old May 19, 2009 | 07:27 AM
hickle's Avatar
all true, beat me to it. except you can BARELY hear the changeover at 4400.
yes, groundbreaking info . just pointing that out.
Old May 19, 2009 | 10:01 AM
98ITR747's Avatar
vtec kicked in y0!
http://www.youtube.com/watch?v=-kBDOM4Ha9o
type-GGSR
Apr 3, 2008 11:31 AM
SimplyTron
13
Oct 13, 2007 02:16 PM
Edgemingsr
Jul 29, 2004 12:09 PM
ssacol
Dec 9, 2003 08:46 AM
arete213
Sep 10, 2001 08:44 AM
