honda crx with b17
Old May 14, 2009 | 10:14 AM
seanhin's Avatar
New User
Default honda crx with b17
I am trying to pick up a tranny that works with my b17 with the S1 code i know i need a cable tranny but what codes will match without having to buy a new clutch. if i get a j1 which i think was one of my other options then will i need a conversion kit or anything to make it fit my clutch? or will it fit still but just change my gear ratio
Old May 14, 2009 | 10:19 AM
ninty7hatch's Avatar
Default Re: honda crx with b17
Any transmission from a 90-93 integra will be direct bolt on and work (they are all cable trans)and a jdm YS1 transmission from a EF CIVIC OR CRX will work and are cable as well
Old May 14, 2009 | 10:22 AM
chivid's Avatar
you dont need to change the gear ratio at all. your probably talking about the mainshaft not working right? as long you got the right clutch for the tranny and pressure plate youll be set.
88SeeOurEx
Nov 23, 2011 01:47 PM
HPfreak
11
Oct 2, 2011 02:30 PM
crxaggtown
Apr 19, 2007 06:33 PM
94_civicEx
Apr 1, 2007 11:05 AM
LittleDevilBmx
Aug 2, 2005 07:28 PM
