Injector question
Old Aug 18, 2002 | 10:04 AM
Rob03Pro5's Avatar
Default Injector question
What size are the injectors on a F22A? This is off a '97 Accord Auto.
I was wondering if GSR injectors (270cc) will fit correctly and if the computer will handle them without going crazy.
Old Aug 18, 2002 | 10:09 AM
Accord94DX's Avatar
Default Re: Injector question (Rob91TSi)
well, the GSR injectors are saturated whereas your accord uses peak and hold style. So the answer is "no" they will not work.
Old Aug 18, 2002 | 10:14 AM
Rob03Pro5's Avatar
Default Re: Injector question (Accord94DX)
ohh.. I didn't know these injectors were p/h. I thought all newer Hondas had saturated injectors. Do you know what size the stock F22A injectors are?
Old Aug 18, 2002 | 10:21 AM
niedejb's Avatar
I believe they are 240cc/min.
Old Aug 18, 2002 | 10:28 AM
Rob03Pro5's Avatar
Default Re: Injector question (niedejb)
Thanks guys!
This is great.. 240cc is plenty for a small turbo application. I'm looking at an FMU with a 12:1 or maybe a 10:1 disc.. and running a small turbo (T3 Super 60) at around 6psi..maybe 7psi. Anyone know where I can get a cheap (read: AirTex) inline fuel pump?
Old Aug 18, 2002 | 10:53 AM
Brandon's Avatar
Life is Suffering
Thanks guys!
I believe http://www.turbo-performance.com.
Old Aug 18, 2002 | 12:31 PM
Rob03Pro5's Avatar
Default Re: Injector question (F22turbo)
Hey great info guys. I really appreciated. F22turbo, would a turbo manifold from a F22B fit on to a F22A? If so, which manifold do you recommend and where can I purchase one? Or do you think I should get an F-Max kit without the turbo and fuel system?
Old Aug 18, 2002 | 01:51 PM
TypeSH's Avatar
I've seen someone use the eclipse turbo injectors on a JDM F22B (pretty much a h23a equivalent), maybe that might work on the other USDM F-series. Look into it if you like.
Old Aug 18, 2002 | 03:13 PM
Accord94DX's Avatar
Default Re: Injector question (TypeSH)
f22b1 and f22b2 manifolds are interchangable. DSM 450cc injectors fit fine.
Old Aug 18, 2002 | 03:49 PM
Nick H's Avatar
New User
this one should be good for ya....
as far as injectors, the ones you have are fine for a mild turbo setup, but if you want something crazy, step up to some larger injectors...good luck!
Old Aug 18, 2002 | 04:10 PM
Rob03Pro5's Avatar
Default Re: Injector question (nickh2k1)
Anyone got any experience with Turbo-Performance.com? I'm gonna try and email them.
Thanks guys, I'm sure I'll be back with a few more questions.. you guys have been very helpful!
[Modified by Rob91TSi, 8:20 PM 8/18/2002]
Old Aug 18, 2002 | 04:21 PM
Nick H's Avatar
New User
they're trustable!
Linked
Aug 27, 2009 09:56 AM
tinymotor22
Apr 16, 2008 06:48 PM
Project_DX
16
Jul 30, 2006 08:09 AM
BlUAc
Jun 7, 2006 08:35 AM
dc2ali
Jul 11, 2004 05:35 PM
