Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Corsport Adjustable Endlinks
Old May 14, 2009 | 09:49 AM
2008fijibluesi's Avatar
Default Corsport Adjustable Endlinks
I bought these because I needed new endlinks, and I was never quite sure how they are adjustable. They didn't come with instructions. Anyone know how to adjust them?
Old May 14, 2009 | 11:36 AM
chiggin's Avatar
Default Re: Corsport Adjustable Endlinks
I haven't ever used the Corsport endlinks myself, but I did find this:
http://www.8thcivic.com/forums/suspe...-endlinks.html
Apparently, you loosen the nut in the middle of the endlink to adjust them. Once everything is adjusted, you tighten the nut back to lock everything in place. Hope this helps.
Old May 14, 2009 | 12:00 PM
Thank you.
Yes I understand you have to loosen/tighten the nut, but I don't know which way is which. Like which way makes the handling stiffer?
Old May 14, 2009 | 03:11 PM
TunerN00b's Avatar
Thank you.
That isn't how they adjust.
You adjust length and the angle between the ends. There is no way an endlink (other than a blade type) can adjust swaybar stiffness.
Old May 14, 2009 | 03:27 PM
ChargedSI's Avatar
I think adjustable means you can use them with different sway bars, not that they control stiffness. Stiffness is going to come from the size of the swaybar.....I think.
Old May 14, 2009 | 06:23 PM
Greg50Lt's Avatar
exactly...i used them on my car and youll hear a noise with them. its not a squeek or anything its a unique sound. i had it on my car and eventually i got tired of it so i took them off last week.
Old May 14, 2009 | 06:24 PM
TunerN00b's Avatar
Correct, unless you have a race car with blade style links. In which case, you rotate them to change stiffness. That should be the only exception.
beoy9
Suspension & Brakes
Oct 17, 2009 09:11 PM
TB123
Suspension & Brakes
Mar 11, 2008 02:56 PM
stagen
Aug 9, 2007 03:40 AM
vinuneuro
Suspension & Brakes
Mar 4, 2007 12:02 PM
RUBZERK
Sep 11, 2004 08:09 PM
