s300 datalogging
Old May 14, 2009 | 09:45 AM
jdm inc's Avatar
Default s300 datalogging
I was needing some info on how to hook a switch up for the datalog on the hondata s300 any help is appreciated. Thank you.
Old May 14, 2009 | 11:18 AM
93turbo16's Avatar
Default Re: s300 datalogging
Do you need help with a switch for the on-board logging feature?
If so it is very simple.
Old May 14, 2009 | 11:22 AM
jdm inc's Avatar
yes if you could give me some insight i would highly appreciated, thanks
Old May 14, 2009 | 11:28 AM
93turbo16's Avatar
If you want to run a switch for the on-board logging all you have to do is choose an input in the program that you want to run the switch to.
I would suggest using the A/C input. It is a grounded input. So run one side of the switch to chassis ground and the other side of the switch to pin B5 on the OBD1 ECU.
When you flick the switch and it grounds the pin at the ecu it will enable on-board logging.
Old May 14, 2009 | 11:33 AM
jdm inc's Avatar
awesome!!! Thanks bro!
I just didnt know where the other side of the wire on the switch went.
Thanks a alot bro...
Dazer 1991
Aug 27, 2012 03:26 PM
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
type Gendy
Aug 31, 2005 06:09 PM
