EF wheel bearing + wheel stud install - see diagram
Old May 14, 2009 | 08:47 AM
Charlie Moua's Avatar
Default EF wheel bearing + wheel stud install - see diagram
[color=blue]
For installing new wheel studs, I am suppose to remove/replace hub bearing.
However in the diagram below it shows 1 bearing, but 2 part#.... (same price).
1) which is the correct honda part #?
2) Besides the aftermarket wheel stud and bearing, is there anything else I need?
Old May 14, 2009 | 09:37 AM
es.roadster's Avatar
Default Re: EF wheel bearing + wheel stud install - see diagram
i think it should be #'s 1, 2 and 26
Old May 14, 2009 | 11:00 AM
sanimalp's Avatar
$cat /dev/urandom
use the latest part number.. you want the 61747 one, not the 61745. Usually what they will do is send you the revised new part anyway, but it never hurts to order it directly.
protip: you may check out your local napa to see what brand of bearing they are selling compared to the OEM brand, because several times now i have found Napa sells the same NSK bearing that Honda does, just at less of a markup. I know it to be true for throwout and pilot bearings, but im not 100% on wheel bearings.
Old May 14, 2009 | 11:30 AM
Tyson's Avatar
it doesnt matter which one you order. theyll only have the latest mfger in stock. theres a different part number for each mfger. plus, the bearing is a new revision, with a new seal on one end. you should make sure you install it in the right direction.
Old May 14, 2009 | 01:23 PM
schueytenten's Avatar
When replacing the wheel bearing, do I need a new number 2 as well?
thanks
Old May 14, 2009 | 01:56 PM
phatrick2332's Avatar
numbers 1 and 2, 1 is the inner dust seal, and 2 is obviously the bearing. Just reuse the snap ring. I would recommend just pulling the knuckle and taking it somewhere to press in and out. Few bucks and a lot less hassles if you dont have a press.
Old May 14, 2009 | 03:30 PM
Crx Jimmy's Avatar
if the snap ring is only a couple bucks I would get it. sometimes they are hard to get out and might get mangled, usually rusted in place
Old May 15, 2009 | 02:24 PM
My plan was just to bring the knuckle, new wheel studs, new bearing and have them install it... Thanks for all the info.
Charlie Moua
Old May 15, 2009 | 02:38 PM
n3h3bkau's Avatar
Depending on longevity I've seen people just press out the hub (it takes the inner/outside race with it), replace the studs, then press the hub back on. However you are exposing the sealed bearing so its not quite as "sealed" as before.
Old May 23, 2009 | 02:24 PM
EE2bitsk's Avatar
so in order to install new wheel studs, you have to do new wheel bearings as well?
and why?
Old May 23, 2009 | 08:21 PM
Tyson's Avatar
you have to at least take the hub off to take the studs out because theres no room behind the stud to push it completely out. you CAN dremel or grind off part of the front knuckle to get some extra clearance to do so. i wouldnt recommend it, but whatever, its doable.
once the hub is off, you dont HAVE to replace the wheel bearing, but its a good idea to since you have the hub off. not mandatory tho.
same with the rear. except the hub IS the bearing in the rear.
Old May 23, 2009 | 09:28 PM
jdavis94teg's Avatar
or just get a whole new complete hub from a .. junk yard. mine was 25 bucks for my ef9
Old May 23, 2009 | 09:30 PM
Tyson's Avatar
ewwww...
Old May 23, 2009 | 09:54 PM
Originally Posted by Tyson
ewwww...
whaatttt, it was A+ condition
Old May 24, 2009 | 12:27 PM
EE2bitsk's Avatar
so re-using the bearings that are in there ATM would be fine?
i mean mine are good right now and i dont wanna pay $80 if i dont need to.
and grinding it off is half assed and cheap IMO.
young_tuner
Feb 8, 2010 01:53 PM
EFstyle
Nov 23, 2008 07:08 PM
XJamesX
Suspension & Brakes
Jun 1, 2005 12:41 PM
92civeg
Feb 27, 2004 08:32 PM
