eBay Brake Kits
Old May 14, 2009 | 07:41 AM
justahobbie's Avatar
Default eBay Brake Kits
I've looked around a little bit but havn't seen anything specifically on the eBay kits or brands. Anyone had any experience with them? I had some killer brakes on my car when I bought it but can't remember the brands now as I'm heading out for work. I see on ebay full kits with slotted/cross drilled rotors and ceramic pads for $175-$200. I'm on a budget and the brakes finally went out on my car. Pedal goes to the floor.
Thanks for the help.
Old May 14, 2009 | 07:55 AM
splitime's Avatar
Default Re: eBay Brake Kits
Don't waste money on cross drilled/slotted crap.
Pedal to the floor is more likely the system needing a fluid bleed. Or the Brake master cylinder or something along those lines.
Old May 14, 2009 | 12:17 PM
Either way I need rotors and pads. I'm metal to metal on 2 corners. Dad's a mechanic so I'll deal with the rest when I tear into it. I like the best but can't afford it now, so I'm about to just go to Auto Zone. Just thought I'd see if anyone could recommend an inexpensive setup. Oh I forgot to add I have stainless steel lines. The setup I had before ate my rotors to almost nothing.
Old May 14, 2009 | 12:22 PM
racebum's Avatar
you mean deals like?
http://cgi.ebay.com/ebaymotors/97-01...#ht_929wt_1134
it's not bad but i would be more inclined to run a blank with a better pad. the ultimates or hps & hp+ are my 3 favs.
jay525
Jan 16, 2019 10:56 AM
schecter
11
Dec 14, 2009 06:38 AM
fatpride111
Suspension & Brakes
Sep 3, 2009 01:17 AM
kxn
Oct 1, 2008 07:31 PM
zirac50
Apr 16, 2007 05:41 PM
