MICHIGAN 2000 civic si PARTOUT milano red.
for partout is a 2000 honda civic si milano red. the car has 125xxx miles on it. im not sure if it runs or drives or not as i cant get the car to start. i think there may be a problem with the starter as my buddy whos huge into wiring and stuff made a jumper harness to bypass alot of stuff and we got nothing, so im narrowing it down to the starter.
car is located in battle creek, mi.
call me if you have any questions.
QUICK PRICE LIST
$600 - trans
$150 - rear disc
$300 - complete front subframe with lca's, sway, steering rack, front brakes.
$100 - rear seats (fronts are sold)
$200 - VAFC II
$200 - trunk with spoiler
$75 - rear bumper cover
$100 - floor harness
$75 - pass side door
if theres anything else you want shoot me a msg.
$600 - trans
$150 - rear disc
$200 - VAFC II
i need all these, sry copied pasted from my WTB added, lemme know if you have
11. OEM Si Lip
18. Inside Fuse Cover (type K)
19. Coin Pocket
20. EK Wiper Arms (for coupe dont know if there is a diff.)
21. Molding assembly on the door, just under the window
22. Heater blower motor and fan
23. passenger rear quarter panel
11. OEM Si Lip
19. Coin Pocket
$65 ecu
$350 wheels, they are all clean and hold air except the driver front one. it needs some tlc but still holds air.
returned pm's
returned pm's
WHATS SOLD
-block/bare head
-carpet
-tailights
-front seats, dash, door panels, armrest, shifter surround. (still have the rear seats)
-cluster
-vafc
WHAT IS STILL GOOD
-trunk w/spoiler ($200)
-rear sway bar setup including trailing arms($75)
-pass door($100)
-pass side skirt($30)
-either 1/4 panel($150 per side)
-rear seats($100)
-wheels($450)
-exhaust(unsure of the brand $200)
-complete intake mani with all sensor($225)
-exhaust mani($50)
-w/linkage and b16b clutch/flywheel setup($600firm)
-complete 99/00 climate control conversion($250)
-complete front subframe with lca's, sway, rack, bigger front brakes($300)
-floor harness($100)
-misc harness'? ($n/a)
-m.c. brake booster ($75)
and i think thats it for now. lmk what you need.
-block/bare head
-carpet
-tailights
-cluster
-vafc
WHAT IS STILL GOOD
-pass door($100)
-rear seats($100)
-wheels($450)
-exhaust mani($50)
front seats are sold but rears are in really good shape. $100 for those and $30 picked up for one shock. (will be a stock si shock/spring combo)
i still have alot of stuff fellas.
complete b16a2 intake mani with all sensors and harness. $200 firm
ecu $65
rear disc $150(no cables or prop valve)
trunk and spoiler $200
front brake setup including sway bar, lca's, rack, subframe. $250
and all harness' $n/a
ecu $65
