b16 sitting too low in crx
Old May 14, 2009 | 12:04 AM
aeenox's Avatar
Default b16 sitting too low in crx
Well i bought a crx today and i noticed the engine sits pretty low. Is this common on crx with b16 swaps?
Old May 14, 2009 | 02:35 AM
~sp33~'s Avatar
EFB055
Default Re: b16 sitting too low in crx
Post a picture?
They don't generally sit very low. But depends where your referencing from.
Old May 14, 2009 | 09:08 AM
scottmog's Avatar
seems strange that an B or D series would fit low since there is not fitment issues. do the engine mounts look fine?
like sp33 said, picture = 1000 words.
make a photobucket.com account and post alot of pictures so we can see what you are dealing with. also be sure to do wheel wells, ur car is probably dropped.
Old May 14, 2009 | 03:12 PM
aeenox's Avatar
Alright imma try to take some pics today. Also when im goin fast and start to slow down fast my car starts rumbling. Could the axles be bad? Or is it something with my brakes. Because I slow down fine but the front of the car starts rumbling.
Old May 14, 2009 | 03:57 PM
bTwink's Avatar
you can just put it in my car and call it a day... my buddys eg has a b16 in it and i think it sits a little low but he doesn't seem to think so.
bumb for the pics!
Old May 14, 2009 | 04:21 PM
Zaakro's Avatar
It depends on what kind of mounts you are using also. If you are using Ebay special than thats your problem. If its Hasport or Innovative mounts then it shouldn't sit low at all.
Old May 14, 2009 | 04:31 PM
aeenox's Avatar
Oh alright cause i got the car with the swap in it already. But i think it might be the mounts cause they look cheap. I will take a money shot and some pics from the bottom of the car.
Old May 14, 2009 | 08:43 PM
aeenox's Avatar
do any of u guys know wat code 7 means??
Old May 14, 2009 | 08:48 PM
jhammond_82's Avatar
Reject Papi
tps
Old May 14, 2009 | 08:51 PM
liquor assassin's Avatar
i know i cannot use a 4-1 header because of how low it sits, i have a b18 though, suprised i havent bashed the oil pan yet on this one
Old May 14, 2009 | 10:42 PM
aeenox's Avatar
wats tps?? im a NoOb
Old May 15, 2009 | 12:28 AM
.Manny.'s Avatar
Touching My Member
uh oh. throttle position sensor
Old May 15, 2009 | 09:28 AM
redflaredcrx90's Avatar
what motor mounts are you useing hasport .innovative ,place racing has the best placement in a ef chassie
Old May 15, 2009 | 02:09 PM
2point2's Avatar
^ nice avatar...
The "rumbling" could be a lot of things. Bad ball joints, warped rotors, worn out bushings on the suspension (including the radius rods).
Old May 15, 2009 | 04:44 PM
aeenox's Avatar
ahhhhh it may be prob the ball joints. when i start slowing down at high speeds the car rumbles and to me it feels like it has something to do with my brakes or the suspension. imma check all the bushings in the front of the car
Old May 15, 2009 | 06:35 PM
aeenox's Avatar
do any of u guys know why my engine runs like this??? Is the belt or gears too loose??
Old May 15, 2009 | 09:27 PM
ryanevansoh's Avatar
sounds like your valves are ticking and need adjustment. also your belt looks a bit loose
Old May 15, 2009 | 11:59 PM
aeenox's Avatar
oh alright coool imma need to get that fixed. cause my engine is running like $hit!!....i wonder how much that is gonna be to fix.
Old May 16, 2009 | 04:23 AM
traxxasx's Avatar
holy crap do now run ur engine anymore that belt is way to loose and i bet it has skipped teeth already causing ur car to run like ****. Redo the timing belt line it all up and tighten the tensioner down good.
Old May 20, 2009 | 12:05 PM
JDM-KIDD's Avatar
It might be i know this guy with a CRX b16 and his left a little dent in his hood from hitting the hood... so it might but.... if it not hitting the ground or speed bumps and all that u should be good
Old May 29, 2009 | 01:59 PM
aeenox's Avatar
Where are the oxygen sensors #1 and #2 located on a b16?? Anyone have pics. Cause i need to check mines out cause my ECU is throwing code 1,2, and 7
Old May 29, 2009 | 02:05 PM
killercrx91's Avatar
Well I read that if you have any B-series in an CRX or civic you have to upgrade the coiloversw to because the engine is goin to be heaveyer.
Old May 29, 2009 | 02:21 PM
Black4thgenEF's Avatar
That is a ridiculous myth.
Your timing is likely off.
Old May 29, 2009 | 02:50 PM
sanimalp's Avatar
$cat /dev/urandom
The "valve tick" is probably bad lma's..
Old May 30, 2009 | 04:37 PM
.Manny.'s Avatar
Touching My Member
x2. a new set and a valve adjustment will get rid of that. and get rid of that huge JG manifold...it's really going to hurt more than it will help.
