Vtec Wiring
Old May 13, 2009 | 06:57 PM
d4rk13l4de's Avatar
Default Vtec Wiring
I know this has been cover befor as i have searched for the answer, i have a civic that was manufactured in 10/92 so does that make it for the Prewired for Vtec? Anything that i find is for 92 Civic but i dont find a cutoff manf. date
Old May 13, 2009 | 06:59 PM
TravisCadello's Avatar
Default Re: Vtec Wiring
Any 92's were prewired to the shock harness. mean you can put a ex/si engine harness and you will have v tec. that or you can run 2 wires from the v tec to the shock harness and one for ground.
Old May 13, 2009 | 07:00 PM
here read throughout my thread a while ago. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/wiring-v-tec-92-dx-body-si-motor-2457228/
Old May 13, 2009 | 07:04 PM
d4rk13l4de's Avatar
what im asking is mine is technicly a 93 because it post 6/92 but since its 10/92 is it still prewired?
Old May 13, 2009 | 07:10 PM
Not sure. check it. let me find the pic for you to check it
Old May 13, 2009 | 07:11 PM
check your out and match it to this one.
http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
Old May 13, 2009 | 07:12 PM
d4rk13l4de's Avatar
in that thread you posted i found the answer, i dont have the orange/white or orange/blue so not prewired. but luckly im ok i can run two wires lol i will be getting the rywire subharness it looks like
Old May 13, 2009 | 07:14 PM
so you have them or not?
Old May 13, 2009 | 07:16 PM
d4rk13l4de's Avatar
its not prewired, so i just have to run the vtec wires into the ecu locations and install the rywire sub harness to have vtec
Old May 13, 2009 | 07:17 PM
0 ya, that sux. good luck though. i got lucky with mine.
Old May 13, 2009 | 07:19 PM
d4rk13l4de's Avatar
thanks, the rywire subharness is like 65 plus shipping could i find a ex/si harness for cheaper or do they go for more?
Old May 13, 2009 | 07:20 PM
d4rk13l4de's Avatar
one other quick question where is the best place to run the wire through the firewall?
Old May 13, 2009 | 07:24 PM
yea, in with the harness. but around the seal.
redbull99
Feb 5, 2016 10:17 AM
Murk 'EM
14
Sep 16, 2007 04:25 PM
quicksol95
Mar 10, 2004 05:51 PM
lonefuzzy79
May 27, 2003 12:41 PM
