Suspension & Brakes Theory, alignment, spring rates....
Difference in Koni Yellow Shocks?
Old May 13, 2009 | 05:23 PM
uses0ap's Avatar
Default Difference in Koni Yellow Shocks?
What would be the best set Koni shocks to consider for the Ground Control set up?
Koni Yellow
Koni SP3
Koni Race
Im looking to slam the car. I understand that the SP3 has an extra 20mm rebound stop limiter and wont bottom out as much as the normal yellows. Im not sure the difference of the Race yellows..are they even shorter than the SP3s? are the SP3s only for the neuspeed set up? Is the upgrade worth the money?
what other options of the Konis are there??
thanks for all the info!
Old May 13, 2009 | 05:58 PM
TunerN00b's Avatar
Default Re: Difference in Koni Yellow Shocks?
The Neuspeed branded Konis do not help with bottoming out. They are the same length. Only additions are additional circlip locations and a larger droop limiter, which I can't think of a valid reason to include.
Old May 13, 2009 | 06:15 PM
verycleanhatch's Avatar
koni yellow and koni sp3 basically the same except the above post.
race has a shorter body but bad thing about those is it's not lifetime and cost lot more.
DC2Monster
Feb 19, 2015 02:29 PM
freeagent32
Honda S2000
Apr 12, 2006 08:54 AM
the soL that could
Suspension & Brakes
Feb 6, 2006 06:27 PM
mingchi69
Jun 29, 2003 05:19 PM
taytay333
Mar 26, 2002 03:54 PM
