obd2 ls valve cover
Old May 13, 2009 | 05:07 PM
bluestd's Avatar
Default obd2 ls valve cover
ok so i have a obd2 ls valve and i know that they both have the breather tube thing on the left but on the 2 it has the extra little one to the right of it my ? is can i just plug the hole up and if yes wat can i use to, o and on mine it's just the hole there no plug
Old May 13, 2009 | 06:51 PM
seanbev24's Avatar
Default Re: obd2 ls valve cover
http://farm4.static.flickr.com/3278/...99e8fc.jpg?v=0
Found that on google images, are you talking about the one with the tube going to the intake manifold?
If so, that is the pcv (positive crankcase ventilation) for the b18b engines. They do it differently on b18a's so the valve covers don't have that. If you are running a b18b engine, I would recommend running the pcv properly unless you are running a breather/catch can setup. Plugging a pcv system will cause blowby and is not good for your engine.
If that's not what you're talking about, sorry I couldn't help.
Old May 14, 2009 | 07:21 PM
bluestd's Avatar
i don't have the plug thats on the manifold cuz it's a b18a motor i talkin about the hole on the valve cover can it be blocked off with a plug? and is it safe
Afireinside2285
Dec 14, 2010 07:25 PM
meyerk9
Nov 10, 2010 02:32 PM
candyman206
Sep 3, 2009 01:39 PM
jdmdc2boi12
Apr 9, 2009 08:46 PM
burnsmonkey
Nov 23, 2001 10:05 AM
